fuel injectors keep clogging
hey guys i have another problem i need help with. this has happened to me about 3 times already. im driving along fine and all of a sudden my car starts slowing down, engine starts shacking and the car begins to drive funny and i get a check engine light. the first time it did this i took it to toyota and they told me it was a clogged fuel injector and that they wanted to clean em' up but were gonna charge me an arm and a leg so i took the car home pulled off the injectors my self and ran STP fuel injector cleaner through them. worked like a charm. couple weeks later same thing. car starts to do the same thing pull off injectors clean them, fine again. now last night it begins to happen and now its ____ing me off. has anyone had the same problem where their injectors get dirty so fast? i use Valero unleaded and every oil change i use the STP complete fuel system cleaner. has this happened to anyone and can you provide me with a more permanent solution...
yea change fuel filter, clean the injectors with a mix of seafoam and gasoline, put some seafoam next time you fill up something like hess, bp, shell or exxon and flog it around for a few minutes to clean the lines also.
DONT put seafoam in the gas tank.
it will end up breaking down all the residue or whatever on the tank walls and may end up clogging the pick up.
just buy an injector cleaner that contains polyetheramine that you can pour in the tank
thanks guys i always suspected valero of being low grade gas, only reason i use it is because of the abondance of valero stores. we have a couple of exxon mobile gas stations around here so i think ill be using them from now on. and i will read that top tier forum, thank you.
i tried that too but the only new ones that are opening up are Valero. the semi - older gas stations are the Exxon and the Mobil gas stations. i do try to stray from using gas stations i have my doubts about though. my friend used this one gas station i refuse to use unless its a major emergency, well he began to pump gas and noticed the gas was coming out a dark brown color. needless to say he complained and got his money back.
steeze69
05-24-2021 03:57 AM
SloTC1
08-16-2018 03:45 PM
