Has anyone tried wrapping exhaust pipe?
Just wondering how the car perform with the thermal wrap wraps around the exhaust pipe, on the xB
If I coat the pipe with the engine coat spray before wrapping, will there be any corrosion issue?
If I'm not mistaken, I think thermal wrap is made for headers or the exhaust manifold. It is to serve two purposes: 1. to reduce the heat in the engine bay, and 2. keep more heat in the manifold/header area so the exhaust gases will flow faster.
i did it to my motorcycle. it also helps if you have to work around the exhaust. you will not get burned as easy as touching hot metal....
rcflyer15
12-05-2014 05:15 PM
