head questions
head questions
How hard is it to remove the cylinder head on the 1NZ-FE? I think I read on another thread that you can do it with the engine in the car. I was wondering if anyone has tried porting and polishing the head for more power? Is there enough meat on the head to shave it down and go from 10.5:1 up closer to 11:1? Anyone try this yet? I'm new to fuel injection so I don't know how this effects the fuel curve. Are there any aftermarket intake manifolds out yet?
Seems like a lot of people are looking for power with turbo and blower options, but there might be 10-20HP hiding in head flow, manifold, and compression.
thanks for your time
Andy
Andy
Re: head questions
I'm sure on an econobox's head there's plenty of flash/crap in the ports, but I haven't seen any pics of our heads.
Heads seem like a resonable place to pick up some hp. Our intake manifolds are short and seem pretty unrestrictive (though I've never seen the insides...) I'm sure some P&P of the ports would yield some decent gains w/o much sacrifice and w/o changing the power curves.
Re: head questions
if you do you would have to run a higher fuel octane
Re: head questions
If you did port the head or add compression, would any computer changes be needed? When you add an aftermarket blower...do any new calibrations have to be made?
thanks again
Andy
http://www.piratesofhorsepower.com
http://www.cobralads.com
If you shave anything off you will decrease the compression by increasing the area the F/A mix gets compressed into, Unless of course you get higher compression Pistons.
Here is an example of what I meant from a head manufacturer's site. These are mustang heads.
http://www.airflowresearch.com/pages/225sbf_rh.htm
At the bottom they say Angle Mill (6cc Maximum Mill) .008” per cc and Flat Mill (3cc maximum Mill) .006” per cc Every .006" you shave off this head drops the chamber volume by 1cc. This same procedure can be done on any head.
Andy
Re: head questions
Are our manifolds ceramic by the way? I guess like on the new vettes. I imagine that leaves a fairly clean port.
port and polish along with a cran cams regrind ( 95 per cam ) would probably net you a decent amoung of power , along with a good valve job. i'd guess about 15 or 20. and milling the head would most def require higher octane , i'd assume theres plenty o meat to be ground down seeing as how other toyot heads i've seen are.
onto another thing yes it can be done with motor in car but is not the easiest task , the valvetrain will be the least fun.
