I NEED HELP: XB ENGINE PROBLEM
Old 04-17-2006 | 07:29 PM
  #41
vintage42's Avatar
[quote="greenguyshrek"... I have already changed the oil once. But i will do it again.... i am going to change the oil one more time and will see what happens. Should i get another oil filter or just use the sameone?[/quote]
I don't see how changing oil can have any effect on possible engine damage, if that is the intent.
Old 04-17-2006 | 07:53 PM
  #42
YourNameHere's Avatar
Exclusive
from my understanding the problem during a "hydrolock" is that water gets in the with the oil. the oil gets diluted i guess you can say. and there for loses its ablilty to lubracate parts causing all sorts of bad things to happen in the engine. if a minimal amount of water is sucked up then changing the oil can solve the problem. but since his oil came out looking like "chocolate milk" the damage was likly already done.
Old 04-18-2006 | 04:16 AM
  #43
YELOSUB's Avatar
Wagonistas
Damn, makes me want to take off my cold air and get a short ram air one instead...
Old 04-18-2006 | 04:46 AM
  #44
frogbox's Avatar
Ok guys, hydrolock is when you get water into the combustion chamber in an amount greater than what can be compressed. water doesn't compress that well. When it gets to that point the pressure in the combustion champer blows everything helter skelter(ever put a can of soda in the freezer and forget about it?)
Valves cannot open, piston doesn't move and boom.
Now with water in the oil, there is a fix, flushing it out real good, the bearings won't be all that good, depending on how much the motor was run but can be "fixed". I'll try to remember the chemical you use to clean it out, there is a commercial name for it. If I can find it I'll post it up, used mostly for flushing coolant out of the oil when you blow a head gasket, which can also happen during a hydrolock condition.
Best thing to do is just replace the motor, it will never be the same.
Old 04-18-2006 | 06:53 AM
  #45
greenguyshrek's Avatar
The dealership still hasent called me back, but as soon as they do Ill post what happens right up.
Old 04-18-2006 | 04:00 PM
  #46
spawnconnery's Avatar
I hope that they are honest with you since you left on your intake and were honest with them.
Old 04-18-2006 | 04:20 PM
  #47
Scott17's Avatar
StyleWagons
I have seen this exact thing happen many times. The valves won't bend because they are closed during the compression stroke. What WILL bend is a rod. This is what usually happens. The bent rod, being shorter now, allows the bottom side of the piston pin boss to contact the counterweight on the crankshaft, causing the ticking or knocking noise. The usual result is one or possibly two (if you were going real fast) bent rods. It can be fixed. The engines don't typically run too long or well after a hydro-lock so water in the oil does little if any damage. All this brings us to the moral of our story; Don't go through high water! and also; Toyota sells and recommends only one particular cold-air intake system and now you know why.
Old 04-19-2006 | 06:47 AM
  #48
SwaTx21's Avatar
toyota dealerships ask way too much unless you "know" them, if your intake is low to the ground (same setup) you should have already known after installation water is an ememy. higher mods equal higher attention tward the parts you installed. stock = "derrrr, dealership covers me right?" forget that, we are the few who look deeper, so think about it when you make a mod.
Old 04-19-2006 | 06:29 PM
  #49
I just got the call from toyota, and they said that they are going to cover it. I am so happy I am getting a brand new engine. I would have paid $2000 just for labor + more for parts. I am so lucky.
Old 04-19-2006 | 06:31 PM
  #50
Thanks for everyones help, you guys are the best. I wouldnt have done it with out everyones input. So THANKS
Old 04-19-2006 | 06:51 PM
  #51
Exclusive
congrats!!! now go get a short ram intake!!!!! RIGHT NOW
Old 04-19-2006 | 08:45 PM
  #52
hotbox05's Avatar
brand new motor? time for me to drive through a puddle or two. my motor is crap.
Old 04-20-2006 | 01:50 AM
  #53
Thats whats up. I am just so lucky. I just have to wait till next week until my ride is done, they have to order all the new parts. I can't wait till I get it back I have so many new parts to put on it.
AEM Intake & Battary Tie Down From Toyota
Steering Wheel & Splash Hub From bBist
Lights From Superfa
Silver Carbon Fiber Shift Boot From Lightning Auto Customs
8000k HID's From Oznium
I can't wait to do all of these installs!!!!
Old 04-20-2006 | 02:16 AM
  #54
bB2NER's Avatar
Music City Scions
That's funny. They won't cover defective clutches but they replace motors that were driven into deep water on purpose. Glad they are taking care of you. Strange none the less????
Old 04-21-2006 | 04:38 AM
  #55
YELOSUB's Avatar
Wagonistas
Damn, you are one lucky dude...Now go and buy a lottery ticket! Congrats......
Old 04-21-2006 | 12:22 PM
  #56
hotbox05's Avatar
EXACTLY
  #57
hotbox05's Avatar
Lights From Superfa
splash hub? wtf?
Old 04-22-2006 | 03:42 PM
  #58
XBdntusee's Avatar
Dude put your oem back on and take it to the dealership. That is what the warenty is for. You most likely bent a push rod some how causing the sound. Just tell them that you were driving the other day in the rain and all the sudden your ride quit running typ of thing. Just play stupid theyll fix it under warenty I betch ya.
Old 04-22-2006 | 06:16 PM
  #59
bB2NER's Avatar
Music City Scions
You didn't read quite enough of the post. They are replacing the engine under warranty (unfreakin believable) . Also, these engines DON'T have PUSHRODS! They are overhead cam motors.
Old 04-23-2006 | 03:07 AM
  #60
Thanks jethro_b
Quick Reply: I NEED HELP: XB ENGINE PROBLEM
