Imagine an xB with a
Caddy NorthStar V8 mount behind the front seats driving the rear wheels. This thought comes to me about once a month, I know it would take a lot of work to do. Just a wild dream I have.
Originally Posted by Lava flow
Here is a Shogun for those that do not know what it is. It's a Ford Festiva with a Tarus SHO engine in the back.
dropping a 350 in the box has come to mind a lot. I have a 383 stroker motor in the garage for my 56 chevy pickup what about putting it in the box instead
Or doing something like this to the box
i saw this posted a long while back this would be sort of similar
Holy torque steer batman!!! CWS tuining did this animal
heres the V8 focus if nobody has ever heard of it. if you havent you gotta see this thing in person. i hightly recomend it
i think this was a sema car in 03. this is fuel injected 4.6
but once that tail wants to see whats around front, you better know how to drift or hang on for the ride...
the car is dirt light and a big motor equals very hairy riding car
i think only 3 were ever made. Jay leno has i think two. one has N2o in it. turbo mag did a article on it a w h i l e back. some people did their own conversons though.
think go kart with 220 HP and light weight car it will be fine ;)
a couple years back when i was on the www.Focaljet.com forums, ford focus tuners put a ZETEC 4 with a jackson racing supercharger in the middle of the car!! i sav a video of it and it was crazy. Since the focus was fords best FWD chassis ever it had near 50/50 and was a go kart on the track with the right suspension SICK
You folks dreaming of mid-engine V-8 power in a box had better get out your tape measures! Maybe with a Toronado tranny...
You might be able to do a front engine/rear drive arrangement if you want to move the firewall back and drive from the back seat!
George
George
This was a thought I had as well. Cut out the rear end and drop in a 3sgte and have a rwd setup since its easy to run around 400hp. I could care less for drifting even though it would take 3 times the practice to do it that with any other front engine rwd setup but this way I get rwd and a street monster that would be untouchable.
the shogun IS different from a porsche 911 setup, if that's what you mean...a 911 is truly rear-engined, whereas the shogun is mid-engined (engine behind seats, but in front of rear axle). if you're referring to a porsche boxster, which i would imagine you weren't because there are plenty of other mid-engined cars and i don't know why you would single out porsche, then yes, they're similar.
the reason the northstar would make for a good mid-engined/rwd scion xB project is: how many other late-model V8's do you know that came in a FWD application? this sets it up perfectly for MR drivetrain layout, as the transmission could relatively simply be adapted to sit slightly forward of the rear wheels and drive them just as it would sit that way over the front wheels in a stock cadillac. can't say it would handle terribly well, but it would probably be a blast on the drag strip. only big drawback is that they were only paired with an automatic transmission...but you could still have an absolute blast at the bracket drags rattling off consistent low 13's with perfect launches every time
