injen short ram intake installation xB?!?
Old 01-22-2004 | 11:41 PM
morph1119's Avatar
Default injen short ram intake installation xB?!?
Hey buds, anyone know a site or have the instructions to installing the intake? Or a place around the san gabriel valley that charges a reasonable price for install? or.......someone around the san gabriel valley willing to help me, ill come to your area so u can help me thanks a bunch.
Old 01-22-2004 | 11:56 PM
Jester's Avatar
All you need to do is remove the battery first. Then, remove the stock intake completely. Your intake should have come with a post-looking thing. That goes on one of the screws that the stock intake was removed from. Then, you will need to remove the sensor from the stock and put it on the injen intake. Then, mount the filter on the pipe. Make sure it's tight and won't slide off. There should be a rubber-looking thing that screws into where the battery sits, so that the intake can rest on it. Finally just mount it on the throttle body and screw it onto the rubber thing and make sure the filter resides behind the headlight and plug in the cables. Hope this helps...
Old 01-23-2004 | 12:10 AM
Exclusive's Avatar
Well I would help you if you were a little bit closer, well unless you want to make the drive out this way If not then it wont be to hard to do it yourself specialy with the install tips just givin above.
Old 01-23-2004 | 12:19 AM
TheRedBox's Avatar
You can do it in less than 10 mins.
Just do what he said.
Old 01-23-2004 | 01:28 AM
morph1119's Avatar
thanks jester that helps a lot, i knew i count on reply right away.peace outs
8URAWD
05-02-2018 03:22 PM
slowcelica
02-10-2015 03:32 PM
arinvolvo
24
11-02-2003 06:30 AM
eric_m
29
10-12-2003 09:22 AM
kidkamel
10-10-2003 07:41 PM
