LSD's for the xB/xA!
maybe, but i dont wana pull the converter out and send it to a company just to have them say, o we cant put a stall in this, or quote so high its not worth it, but a 25-3000 stall in the box would make it haul BUTT!!!
too bad OBX doesn't make LSD for the older xb....
coz i saw OBX LSD for new xb and tc....
and they aren't that expensive (around $400-500)
the KAAZ is a little pricy....
so... no one knows if there an alternative for LSD?
Originally Posted by Wattage
Any one install one of these yet?
I can't take 1WD much longer!
i installed it myself. you need the shop manual because u have to take apart the gear box. i also recommend ordering up a new set of bearings from the dealer. you have to follow the OEM instructions!!!!!!!!!!!! From torque specs to thread sealant to gasket sealing.... I live in chicago and I can say that it has helped with winter driving and has eliminated some but not all of the wheel hop. It is worth the money! but it will cost $$$ in labor if you have a shop install it.
have torque damper. poly-urethaned my motor mounts and LSD and still have some wheel hop. Rims are a bit on the heavy side and running Falken Azenis RT Summer tires plus a clutchmasters and turbo......uhh, yeah FWD aint the most ideal setup
