Modifying signal from rear O2 sensor
I'm building a full header-back exhaust and need to trick my second O2 sensor into thinking the cat is still there so I don't throw codes.
I've found a trick that should work, but a few questions:
Do the 1NZ-FE engines use a narrow band rear O2 sensor?
If so, I should be able to solder a 1,000,000 ohm resistor and a 1 micro-farad capacitor across the signal and ground wires to raise the voltage seen by the ECU (as if the exhaust was still passing thru the cat)
On the upstream sensor, to trick the motor into going rich for turbo/super applications.
I'm not going to use a spark-plug chaser, since I'm welding the whole thing I might as well just use some 3/4" black pipe and set the bung back a bit. Any idea on how far? Just enough to pull the tip of the O2 sensor out of the exhaust?
Google CEL eliminator images to get an idea. Sometimes you have to dial it in with the length so it's better not to make it a permanent setup.
tCing_U
04-09-2013 04:46 PM
