New intakes on the horizon?
Old 09-08-2005 | 12:53 AM
CKGuY914's Avatar
Default New intakes on the horizon?
I've just recently decided that I want to put an intake into my one month old xB and I have decided on the Injen IS series Intake for Scion xB (IS2100P).
But through some readings I've came upon several posts where people said that several companies are comingo out with new lines of intakes, are these rumors true? If so should I wait for them to coming to see if they are better?
Thank you for your helps.
Old 09-08-2005 | 08:02 AM
cid_mcdp's Avatar
Far as I know, Injen is still one of the top two intakes for the xB. Seems like that'd be hard to beat. I mean, it's just metal tubing with bends in it. Seems like it'd be hard for someone to come out with a product that vastly improves over Injen or K&N's designs.
Old 09-08-2005 | 09:42 AM
quadoptix's Avatar
hks got one in the works =) woot woot. i currently have the blitz and its great for being a filter and adapter..i too also have had injen and had many problems w/ it blow out hte map sensor.. it gets hard explaining to the dealer why my "stock" xb blows out map sensors like no tomorrow.
Old 09-08-2005 | 12:09 PM
Chimmy3's Avatar
there's not too much sense in waiting for a better product to come out... its hard to imagine anything coming out that would be so revolutionary that it would be so much better than the current intakes available.
At best, the only reason to wait would be to see if people come out with cheap knock-offs of current products.... which they kind of have already...
Old 09-13-2005 | 04:51 AM
TheComputerMan's Avatar
well, against everyones opinion, i am trying the Perrin and it should be here tommorow. I will definatly post pictures as well as a review about the performance, if any. :D
Old 09-13-2005 | 04:59 AM
Bearwithmee's Avatar
I have had my mass airflow sensor replaced because of my injen intake (both times I had to replace the stock airflow unit before the dealership would touch it under warranty). I've finally decided to go back to stock. The little extra go was not worth the headache. If I were to purchase another intake, I'd probably go with AEM because it's what the dealership offers.
However, I heard from a buddy at work that the MAS can be replaced or upgraded to a unit meant for handling a higher airflow. Does anyone know if this is the case. Have those of you with f/i had to replace this part ?
Old 09-13-2005 | 05:09 AM
TheScionicMan's Avatar
I have the Injen CAI and haven't had any problems with the MAF. Most of the times I read of problems, it was from oil from the filter or not wiping out the tube before install. I'm sure there are many other instances tho
Old 09-13-2005 | 05:20 AM
hotbox05's Avatar
my aem has never hurt my maf. so when will my aem be carb legal it's been carb pending for almost 2 years.
Old 09-13-2005 | 05:01 PM
Simplyscion's Avatar
Team No Limitz
map sensor?? did you switch it up to manifold absolute pressure or somethin?
Old 09-16-2005 | 11:29 AM
MiddleAgedGuy's Avatar
As several people have noted, the AEM intake has been dropped from the Dealerships. Stopped by my dealer yesterday, and I found out why.
TRD is offering one now, at least for the xB. The accessory brochure I got does not list any specs, but if you want a dealer warranty, that's your choice.
Old 09-16-2005 | 11:00 PM
joe52985's Avatar
sIcKsCiOnS
the maf sensor problem was fixed when they released that little filter that goes on the vaccum hose (is that a vaccum hose?). any newly bought intakes wont have that problem. ive said it a million times, injen or k&n are the best out there, and they are so cheap its not worth waiting. also if you pay more than 150, your paying too much
Old 09-26-2005 | 05:41 AM
squirrel's Avatar
Default Re: New intakes on the horizon?
Yes, a new line of intakes for the xB will be out shortly.
Old 09-26-2005 | 01:48 PM
Sciond's Avatar
Get the YDR...can't beat it...
sciontc008
Scion tC 1G Aero & Exterior
01-20-2016 05:10 PM
airmankevin1
11-17-2015 05:44 AM
vi3tb0i09
09-23-2015 08:32 PM
excessads
09-15-2015 05:28 PM
Quick Reply: New intakes on the horizon?
