NGK Iridium spark plugs installed today
Old 01-24-2008 | 10:18 PM
  #41
dugzilla's Avatar
Originally Posted by bB2NER
Originally Posted by dugzillaxb
Or you can order the NGK - BKR5EIX 11 they are already gapped to .044
Is this number the same heat range as the other ones that are for the xB/xA?
It's the plug they list for the bb.
Old 01-25-2008 | 12:41 AM
  #42
snowromance's Avatar
im new to this whole spark plug thing, my tc has 51000 miles should i change my spark plugs? and if so wat are good sparkplugs and where can iget them...thanx alot
Originally Posted by kylelewis32
new sparks huh. ive never looked into it but what all does it do for you in a tc
You kids gotta take an automotive class! ;-)
Old 01-25-2008 | 12:46 AM
  #43
bloody_mess's Avatar
ok then
Old 01-25-2008 | 02:30 AM
  #44
stew32's Avatar
Then you don't have to worry about breaking that tiny electrode.
I think all iridium come pre gapped. They have the little plastic collars. You can double check the gap if you really want but shouldn't be necessary.
Old 01-25-2008 | 02:48 AM
  #45
dugzilla's Avatar
They do come pre gapped, the BKR5EIX is gapped at .032
the BKR5IEX 11 are gapped at .044
Old 01-25-2008 | 03:32 AM
  #46
tanakasan's Avatar
Yes, I had to re-gap my BKR5EIX from .032 to .044.
Old 01-25-2008 | 04:31 AM
  #47
MR_LUV's Avatar
Administrator
Administrator
Originally Posted by MR_LUV
Just check the gap when you get the plugs.
It may not be necessary to gap them.
Mine was .032 out of the box.
That is what the Manufacturer recommends:
http://www.ngksparkplugs.com/part_fi...engineid=37362
MR LUV
Actually the gap on these Irridium plugs should be set at .044 NOT .032. The plugs allow the use of the wider gap to create the hotter spark with the same voltage. The wider gap is what helped increase the mpgs by about 2.
I am going by the Manufacturer's Recommendation
which Clearly States Setting the gap to .032 and NOT .044
and the Fact my NGK Iridium plugs came pregap at .032
Where is your Link to set at .044?
MR LUV
Old 01-25-2008 | 12:04 PM
  #48
dugzilla's Avatar
the manufacturer recommends that we don't mod our cars either, lol.
Old 01-25-2008 | 03:39 PM
  #49
Duncan1's Avatar
What do you guys think of the Bosch Platinums that don't need to be gapped?
Old 01-25-2008 | 03:44 PM
  #50
rosedaleny806's Avatar
yes i do
Old 01-25-2008 | 04:01 PM
  #51
tanakasan's Avatar
I'm sure that they are a good product.
But I've always used NGK/Denso in Japanese cars, Bosch for my VWs and Champion & Autolite for my Chevys and Fords. Just me though!
Any plug that sparks will function. But I always check the gap to insure that it is running at optimum settings.
Old 01-25-2008 | 10:38 PM
  #52
Zombietime's Avatar
I've got on a cheaper set of NGKs but all i've done since owning my 05 xb for 3 years now is change the oil and keep air in the tires. Runs like a champ but it only has 35k miles on it. I really should get new tires soon and maybe change the manual tranny oil but definately not necessary.
Old 01-26-2008 | 04:06 AM
  #53
bB2NER's Avatar
Music City Scions
MR LUV
MR LUV
That is up to you. You just won't see the full potential of changing to irridiums tho. no biggie
Old 01-26-2008 | 08:57 AM
  #54
Guest
Guest
Posts: n/a
I have the NGK plugs in my xB as well. I will never go back to anything else. They work great and my car works better because of it.
Old 01-27-2008 | 03:19 AM
  #55
tanakasan's Avatar
I see that the NGK spec is .032 but I can say that the xB ignition has had no problems with the .044 gap. Seems to be more responsive and efficient so far. Want to run a few tanks through it to see if the mileage is any better.
Old 01-27-2008 | 05:44 PM
  #56
stew32's Avatar
NGK specs .044 gap for tC plugs. Someone with an xB or xA must have seen the larger gap setting and decided to try it.
Does anyone have first hand experience by installing their xB plugs with one gap, then regapping them later? I think the benefit of the iridium plugs comes from the smaller center electrode, not necessarily from increasing the gap. The Denso plugs I installed say they're pregapped to .028, I didn't check or change them, and still noticed a difference.
Also, the electrodes will erode and the gap will increase with use. Setting a .044 gap may work fine now, but you may have to regap later. Set it to the recommended and it should be fine until it's time to change them. I like to mess with my car but only if there's a tangible benefit.
Old 01-27-2008 | 05:52 PM
  #57
dugzilla's Avatar
All I know is the gap for the bb is set at .044 on the same motor, why would that be? Maybe different fuel? idk
Old 01-27-2008 | 08:49 PM
  #58
bB2NER's Avatar
Music City Scions
Yes, I did that. When I first put them in I folowed the factory gap settings. Then I found out about the .044 and reset them to that and noticed an slight improvement in mpgs, power and smoother idle.
Old 01-28-2008 | 01:34 AM
  #59
tanakasan's Avatar
WooT! I have JDM spark plug gap!
Old 01-28-2008 | 05:17 AM
  #60
bB2NER's Avatar
Music City Scions
JDM FTW!
