NITROUS EXPRESS (NX) SYSTEM
Originally Posted by IICEman
dont have nx system but I do have a nos system. works pretty well but its only a 30 shot.
it is drilled into my intake. it is a dry shot. The kit is a Sneeky Pete kit. 10oz bottle that I have mounted to the jack cover under my seat. my switch and button are in my dash just below the cubby.
Originally Posted by Rocket
This is the front seat on my Mustang, I was thinking of switching the kit over to my box, What do you think...is a 400 shot to much???
Yes Rocket please do it, i will fly to PA just to see your xB fly to the moon or would that be explode to the moon.
its just a gentle increase in speed. nothing like throwing you into the seat. thinking about stepping up to a 50 shot, but would like to go turbo instead. as for fuel I have an apexi s-afc but havent had a need to add any fuel with such a small shot.
Here's an honest question for you. Is the gentle increase in speed, worth the money you spent on it? Are you gonna still run the 30 shot if you get a turbo?
I think if you pick the kit up for $200 like you can on ebay then yes I do say it is worth it. I mean gentle by its no big kick in the butt, but you do feel the pedal drop under your foot. I will probably still run the 30 shot if I go turbo.
I dont use it that often. maybe once a month when I get the feeling to. When I first installed it, it was used alot more probably a couple times a week. havent had any problems come from it at all. and I installed it on my car at I think 500 miles.
I'd go wet shot just for sake of not having to set up a fuel system for the nitrous. That way when spraying, fuel + nitrous will be added together with the correct ammount needed to compensate for one another. I ran it on my previous car and worked great. Though if i thought about it for the xa, i'd have to say, i'd run a wet kit with a pedal switch ( meaning, after turning the system on, it only sprays when the pedal is at full throttle ) And probably nothing more then a 50 shot as the very most unless building the motor up to handle more.
well then the kit your talking about is a kit like the zex set up. but for the overall fuel ratio on the xb it is slightly rich so with a shot such as mine at 30 hp it will not lean out the fuel ratio enough to do any damage. just my thought though. but yes a wet kit is the safest way.
mc1114
08-12-2015 02:07 AM
Subaru86
07-31-2015 04:33 AM
