Nology Hot Wires Installed
Old 05-10-2005, 06:57 AM
cee_dub2003's Avatar
Default Nology Hot Wires Installed
I just installed the Nology Hotwires. also installed some Iridium spark plugs. My impression is that with the new plugs and wires car does rev up a bit smoother. The idle does become smoother. I would recomend the wires for sure, and it gives the engine bay a trick look.
Here is a link to my photos of the installed wires. Sorry didnt know how to post the picks.
http://pg.photos.yahoo.com/ph/cee_du...bum?.dir=/4114
cee_dub2003 is offline
Old 05-10-2005, 07:34 AM
hotbox05's Avatar
hmm i'd have to see dyno results before buying more wires to go between my coil and plugs. that imo could only hurt performance
hotbox05 is offline
Old 05-10-2005, 07:35 AM
hnefrdo's Avatar
wow. that looks awesome. how much did you get it for?
does the stock engine cover still fit over all this stuff??
hnefrdo is offline
Old 05-10-2005, 04:58 PM
McBain's Avatar
Default Re: Nology Hot Wires Installed
You cant be serious... There are no gains to be had with wires and plugs UNLESS you had a problem with the set you replaced. You are only experiencing the "performance improvement wishing" syndrone.
McBain is offline
Old 05-10-2005, 05:05 PM
SCI_TC_GUY's Avatar
^^^ I agree!!!! unless the need for increased spark or more powerful spark is present, you're not gonna fell any difference......IMO
SCI_TC_GUY is offline
Old 05-10-2005, 07:09 PM
From what i understand the Nology wires Have a built in capacitors in the wires which allows time for the small coil packs to charge up and give a stronger spark to increase spark to the plugs. My original spark plugs were the regular NGK plugs. so going with the Iriduims i feel a bit of improvement.
Old 05-10-2005, 08:05 PM
hotbox05's Avatar
hmmm lets see dyno
hotbox05 is offline
Old 05-10-2005, 08:20 PM
StyleWagons
Scott17's Avatar
What he said!
Scott17 is offline
Old 05-10-2005, 08:21 PM
McBain's Avatar
You already have more than enough spark in stock form. The regualr NGK plugs are more than adequate. The plats and irridium can last longer and are popular in hard to reach applications as you dont have to change them as often. You will not gain anything from using these plugs in this engine.
These engines are designed to meet very tough ULEV requirements. A strong spark is already there .. capacitors in wires ? seems more like marketing than engineering... there is a rise/fall time for caps to function properly... less is more, no wires are best, direct spark which some cars use... having longer wires with caps or whatever seems counter productive..
McBain is offline
Old 05-10-2005, 08:32 PM
hotbox05's Avatar
mcbain these cars come with ngk plats. but i do agree with most of your post
hotbox05 is offline
Old 05-10-2005, 08:35 PM
McBain's Avatar
interesting.... why the 30K mile change then? These plugs are used in applications that go to 100K. I doubt they perform well up to that point, but they do better than standard for long use. Thanks
McBain is offline
Old 05-10-2005, 08:40 PM
Hotbox: i just looked at my old plugs and they were the regular ngk "R" v-power spark plugs . Are they really suppossed to come with Platinum plugs. If so why were my Oem only the regular plugs?
Old 05-10-2005, 09:05 PM
hotbox05's Avatar
I was told they were platinum. hmmmmmmmmm i'm wrong , i apologize. fike.. but yeah i'm waiting on dyno.
hotbox05 is offline
Old 05-10-2005, 09:52 PM
Chimmy3's Avatar
yeah i looked at mine and they weren't plats either... maybe another 04-05 changeover?
wasnt this brought up in the past when they were fitted on the xA?
for about 200$ i'm dubious of the gains...
Chimmy3 is offline
Old 05-10-2005, 10:10 PM
hotbox05's Avatar
I thought it was like 295. hmm either way it'd be interesting to see if any gains are to be had
hotbox05 is offline
Old 05-11-2005, 12:39 AM
LavaBox_v1's Avatar
Where did you buy them at and what was included in the package?
LavaBox_v1 is offline
Old 05-11-2005, 04:04 AM
I bought them from WWW.mmrusa.com for $189.95 in the kit is everything you need to install the wires. 4 wires/coil bracket/ nuts and bolts/ extra ground strap/ and insturctions. it is even CARB exempt. big plus for california.
Old 05-11-2005, 05:48 AM
hnefrdo's Avatar
hnefrdo is offline
Old 05-11-2005, 05:49 AM
From what i can see it will not fit back on ..
Old 05-11-2005, 01:33 PM
LavaBox_v1's Avatar
Thanks for the info ... I think I might have to get me a set of thoes!
Quick Reply: Nology Hot Wires Installed
