OBX 4-2-1 header
Old 01-17-2009 | 09:10 AM
JorG's Avatar
Default OBX 4-2-1 header
Hi everyone (i am fairly new here)
i was searching for xb parts on ebay and came across this header
http://cgi.ebay.com/ebaymotors/OBX-L...Q5fAccessories
this looks exactly the same with WR header...
does anyone know if there are any performance difference between the two?
i also notice the OBX has the tab for mounting onto the OEM bracket...(it seems better)
thanks
Old 01-17-2009 | 01:33 PM
xBHAWK's Avatar
Default ....Limited slip header.....
WoW, yes.... OBX 4-2-1 Header is great, get that knock-off and install it.
The e-bay link is for a differantial.
I got a cheap e-bay header for $25, but it has no way to re-attach the heat shield.
I would prefer to have the heat shield.
Check your link.....
Old 01-17-2009 | 02:05 PM
dz302's Avatar
Default Re: ....Limited slip header.....
So can someone expect seat-of-the-pants improvement by installing a good header on the xB? I have been thinking of doing a header with a good "mellow" muffler. I don't like loud and blatty sounding exhaust.
Any suggestions?
Old 01-17-2009 | 04:21 PM
sdsnybny's Avatar
I have had the OBX 4-2-1 header for @ 2 years and its great you will feel an improvement in performance mostly in the low end torque.
Old 01-18-2009 | 12:29 AM
Grant314's Avatar
For those of you who have this, are the bolt holes threaded? Were you able to use the stock bolts/springs?
Old 01-18-2009 | 12:34 AM
sdsnybny's Avatar
yeah they are threaded and I used my stock gasket(doughnut) and spring bolts
Old 01-18-2009 | 12:45 AM
JorG's Avatar
sorry ...
this is the right link...
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=200299875831
so... with the 4-2-1...
i shouldn't expect much high end gain?
Old 01-18-2009 | 06:12 AM
burstaneurysm's Avatar
No, the 4-2-1 will give you a bump in the low-mid end. A 4-1 is better for higher end.
Old 01-18-2009 | 06:29 AM
jct's Avatar
jct
just don't match a 4-1 header with a cold air intake = no low end power
Old 01-18-2009 | 10:06 AM
JorG's Avatar
oh..
that's a good tip...
coz i have a CAI
thanks!
then, 4-2-1 is probably my best choice..
now... just need to decide if i should go with OBX or WR...
Old 01-18-2009 | 03:51 PM
evosky's Avatar
i have a strup 4-1 with the AEM CAI.
i still have low end kick, it's not bad at all. and when you get to 4K, everything really kicks in.
Old 01-18-2009 | 05:27 PM
dz302's Avatar
That's mostly what I'm looking for is low to mid gains. Most my driving is around town and some gains down low would be nice, especially with the automatic.
Thanks.
Old 01-22-2009 | 08:32 PM
chadr225's Avatar
remember you get what you pay for....and with that said, I am one cheap scion owner!!!
Old 01-28-2009 | 11:12 PM
Grant314's Avatar
I purchased this and recieved it today. Surprised and happy to see mounting tabs for the stock heat shield, as the pic on the auction I won didn't show this. They've updated the pic on the current auction to show the tabs. Hopefully I will get to install it this weekend.
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Old 01-29-2009 | 01:43 PM
xBHAWK's Avatar
Good find. I might just buy this one and chuck my cheap e-bay header that was $25.
Please let us know if the OEM HEAT Shield goes back on that correctlly.
4 pipes into 2 pipes into one pipe!
Old 02-01-2009 | 07:41 AM
Grant314's Avatar
Installed today. Support bracket didn't line up so it's not being used. The heat shield tabs didn't all line up either. I had to grind out a little bit of one of the top holes in the heat shield in order to get both the tops holes to line up. The bottom two are tabs way off, probably an inch away from the bottom holes in the head shield. New holes would need to be drilled for the bottom screws, but just having the top two screws on tight keeps it on snug with no vibrations. Other than that, had no problems with the actual header fitment. Re-used doughnut gasket. Already had a K&N cai and Strup exhaust. While driving around tonight, I felt smoother and better acceleration throughout RPM range. Didn't hit the highway, but definitely noticed better around-town acceleration, like in the 3-4krpm range. The few times I floored it, felt it pulled better overall, and adds some chop to the overall sound.
Old 02-01-2009 | 07:51 AM
sdsnybny's Avatar
I used only the bottom bolt in the block and pivoted the block-to-header support over to the header, then tightened the 2 bolts up, it fits good that way.
the header was designed for RHD cars witch have other parts in the way so the header tubes are moved over compared the our U.S. headers.
Old 02-25-2009 | 03:48 AM
boxman27's Avatar
i have checked this header out before and have wondered about it. thanks for the great info. how loud is you car now with the header on im not looking to be a cop magnet or anything just want a little more pep and mileage would be nice too
Old 02-25-2009 | 06:59 AM
JorG's Avatar
i just got one last week and installed today...
pretty easy install...
(the hardest part is probably getting the cowl off.)
took me around 1 and a half hour.
Like Grant314 said... bottom 2 heat shield tap doesn't line up.
braket bolt doesn't line up.
for noise-wise... i don't think there much difference... may be just a little bit more throatier...(deep sound, but just a little bit more)
Performance wise, doesn't feel as draging as before when climbing up the RPM.
Old 02-25-2009 | 08:02 AM
boxman27's Avatar
cool i think im going to get one for my box
