Project Vitz Rs turbo
Just a little teaser for you guys.. A shop im working with in japan is locating a motor from a Vitz Rs turbo. The Motor will most like be older one since those motors also came in the DB and Voxy. The motor i believe is rated at 150hp and 148lbs of torque from the factory.. Let the madness begin...BWWAAHAHAHAHHAHA :twisted:
And the status is...........
Still waiting to find a good motor!! lol.. They informed me that they do have a newer engine... 2001.. But they are asking a little too much for my pocket book. So i'll wait until i get another decent one... Hopefully this will work out. Already got confirmation that modacar will handle in install...
:twisted:
BWWAAHAHAHAHHAHHAAHHAAHAHHA
:twisted:
that's what im trying to figure out. and it seems like im not gonna get a responce back from japan til monday. modacar actually might sponsor me if this comes into play.. it's a 50/50 split right now as to if its going to happen or not. They turbo kit that the vitz comes with is JDM TRD, and should bolt right up. My only concern with that is tuning. Im trying to figure out whether or not the motor is low compression, or if they just slapped a turbo and some pipes on it...
Originally Posted by showpaojoe
Is it possible to get the turbo kit for the vitz and put in ours? same 1nz-fe so whats the difference?
The vitz kit uses a t25 turbo and I could get one from Trust but not if it doesn't fit the 1nz-fe. i haven't really looked at the difference but I just saw that the vitz rs uses the 1nz-fe, just hopin I guess :D Thanx for the info risen_, gotta do quite a lot more research on my end.
2001, beginning, build, building, difference, engine, gearbox, kit, motor, project, rs, turbo, turbocharger, turbokitvitz, vitz
