pulstar plug = waste of money
Old 01-25-2008, 06:25 PM
jct
jct's Avatar
Default pulstar plug = waste of money
http://www.pulstarplug.com/howtheywork.html
jct is offline
Old 01-25-2008, 07:36 PM
Gman1028's Avatar
I like how it says if you don't use this power to go faster it will help you save at the pump a whole 2.2% on the toyota corolla with the 1.8 LITER. Hey that equates to a whole .66 mpg increase if you avg 30 mpg
11 GALLONS
.66 MPG
YOU GET A WHOLE 7 MILES EXTRA PER TANK
If you drive 15000 miles a year you'll use approximately one less tank of gas a year
Thats complete woth the extra cost
Gman1028 is offline
Old 01-25-2008, 07:42 PM
Dkfung88's Avatar
lol they're trying pretty hard to sell those sparkplugs
Dkfung88 is offline
Old 01-25-2008, 08:53 PM
jct
jct's Avatar
i read some where they did a test on all the fancy spark plugs on a neon srt-4 even thou the pulstarplug did get the most hp numbers out of it the
your still better getting the denso iridium spark plugs way cheaper and those plugs came in second and it made the most torque numbers out of the bunch!
jct is offline
Old 01-26-2008, 02:24 AM
swartzautoman's Avatar
what bout the NGK iridium
swartzautoman is offline
Old 01-26-2008, 03:17 PM
Gman1028's Avatar
The iridium plugs are worth the money I have used them in a couple vehicles
Gman1028 is offline
Old 01-26-2008, 03:38 PM
jct
jct's Avatar
http://www.sparkplugs.com/sparkplug4...Results&mfid=0
jct is offline
Old 01-26-2008, 06:26 PM
jct
jct's Avatar
most ppl are comparing it to the nology hotwire kit and they are right about it too
jct is offline
Old 01-26-2008, 06:37 PM
Dispatcher138's Avatar
Are the hotwires not worth it?
Dispatcher138 is offline
Old 01-26-2008, 06:43 PM
Big Sky Scion
SciontCya's Avatar
Have to admit, the site is very well done...
But I think I'll pass...
SciontCya is offline
Old 01-28-2008, 03:24 PM
Team XcelsiA
SHIFT_xA's Avatar
No, well at least not for our cars. They make coil on plug to have the electricity go directly into the spark plug, the design is far superior, adding any wires to that is worthless and could adversely have a worse effect on the car rather than a performance gain.
SHIFT_xA is offline
Old 01-28-2008, 05:13 PM
jct
jct's Avatar
in 6-18 months they will go bad
jct is offline
Old 03-07-2008, 08:50 PM
Retrospect's Avatar
Where's the best place to order a set of iridium plugs?
Retrospect is offline
Old 03-07-2008, 10:48 PM
burstaneurysm's Avatar
Scope this thread.
https://www.scionlife.com/forums/viewtopic.php?t=207682
burstaneurysm is offline
Old 03-10-2008, 03:36 AM
Sciond's Avatar
I have over 60,XXX on the Denso Iridiums
Sciond is offline
Old 03-10-2008, 07:19 AM
divisii's Avatar
Pulsarplugs, like capacitive discharge, & nology are an old school solution to the inherent weakness found in spark plug wire systems.
Okada Project, plasma ignition coil packs kit.. uses the same technology as the pulsarplugs; & it sounds like it'd be a more reliable replacement for a coil over plug design like ours.
... they're all about eliminating misfires under scenarios that fall outside manufacturer's tolerances; so it's likely these products are of little benefit to street tuned vehicles.
divisii is offline
Old 03-11-2008, 03:35 AM
Sciond's Avatar
add Jacobs to the above list....
Sciond is offline
Old 03-18-2008, 06:05 AM
Music City Scions
bB2NER's Avatar
Ebay has some NGK Irridiums for like 30 bucks a set shipped. Just make sure you get the part number for the bB tho. They come pre gapped at the proper .044 gap.
bB2NER is offline
Old 03-18-2008, 06:17 AM
Music City Scions
bB2NER's Avatar
Here is the ebay link for the plugs
http://cgi.ebay.com/ebaymotors/4-NGK...em130197865833
bB2NER is offline
Old 03-21-2008, 05:42 PM
masafina's Avatar
$24.95 each
no way$100 for 4 plugs
mine has ngk$2.50 each and goes point A to point B pretty well jajajajajajaja
masafina is offline
Quick Reply: pulstar plug = waste of money
