Replaced the fuel Evaporative Canister..
Old 07-04-2016 | 10:54 PM
douglasinct's Avatar
Smile Replaced the fuel Evaporative Canister..
Yes, it was time to replace the Evaporative Canister assembly.
- The 3 error lights, codes, and a weeping leak on the unit.
I found this video to be very helpful.
I biggest difficulty I encountered was the removal of an upper right-angle hose fitting coming from the gas tank.
After discovering that the fitting's 2 tabs to release the fingers on the fitting did not work as advertised, I spent 2 frustrating hours using a right-angle pick to get them over the molded ridge on the unit pipe.
Finally, I was able to manipulate the fingers without destroying them and remove the fitting.
And that, class, is how I spent my 4th of July.
__________________
Last edited by MR_LUV; 08-25-2019 at 06:55 PM. Reason: Moved to Correct Forum by Administrator
Old 07-04-2016 | 11:53 PM
jct's Avatar
jct
with mine it was the valve/solenoid on the canister and since that's not a separate part to order
Old 07-07-2016 | 05:16 PM
It was fun to see the carbon particles falling out of one of the larger pipes on the unit.
PS:
My back still hurts 3 days later from being on the concrete driveway.
Also replaced the Purge Valve unit that clips onto the Air Intake box in the engine compartment... just for good measure.
Next Task
Replace the Pre-Cat Oxygen Sensor
Looks like I can order that (NGK 24111) from Autozone for about $92.
Old 07-08-2016 | 02:07 AM
jct's Avatar
jct
you need a floor mat or cardboard to lay on... good luck with your O2 sensors...
Old 07-08-2016 | 05:11 PM
Smile MAGIC ! - No 3 Lights
Okay, I put the vapor canister in on Monday afternoon (july 4).
Today, (Friday, July eight), after 100 miles....
Each of the dreaded "3 Lights" disappeared, and I suddenly felt better acceleration.
Next step:
Get another scan to confirm or deny that I need to replace the upstream O2 sensor.
Old 07-08-2016 | 07:12 PM
jct's Avatar
jct
i use this
UltraGauge OBDII Scan tool & Information Center
Old 07-18-2016 | 08:58 PM
chabruce's Avatar
I also had the "terrible three" warning lights, turned out the solenoid as well as the evap canister needed replacing. So after replacement, no warning lights and an extra 2 MPGs.
Old 08-25-2019 | 04:35 PM
pjl52's Avatar
Default If you cannot get the right angle gas fitting off...
Just trim and attach using a hose clamp. Have done this several times without problems.
Phil
Toyota Corolla Evap Canister Replacement - YouTube
Old 08-25-2019 | 04:44 PM
pjl52's Avatar
Default If you cannot get the right angle gas fitting off...and avoid Dorman vc
ALSO--A WARNING-I bought a Dorman replacement from Partsgeek which lasted a few days less than 3 years. The solenoid stopped working--which is the usual failure mode. I would advise not buying this brand. I note that if you buy from Advance Auto there is one with a 3 year guarantee which would have been a money saver.
Phil
Crab_Spirits
08-17-2021 01:12 PM
jdanticoli
36
09-22-2018 11:48 PM
megaman3410
09-04-2014 08:27 PM
gryscion
05-21-2010 09:55 PM
LowerLevelMan
13
04-19-2009 07:15 PM
