snorkel removal
Old 06-08-2006 | 07:30 AM
george_da_2nd's Avatar
Default snorkel removal
anyone removed the "snorkal" that runs form teh air box to behign the headlight? how do i do it and is tehre any sound diffreance?
Old 06-08-2006 | 02:18 PM
Subcompact Culture's Avatar
Basically, get a flat-head screwdriver and you can push one of the tabs down and you'll pull it out. It might take a bit of force. I experimented making a custom intake (it didn't end up working as I had planned). My guess is there wouldn't be much sound difference. Maybe a bit, but not much. The custom intake I made, which was essentially an induction box, made very little noise. Then again, it was kinda hard to hear it over my Espelir JGT500 exhaust.
Old 06-08-2006 | 04:08 PM
ASC's Avatar
ASC
George,
Just a friendly suggestion here - you may want to read my recent findings about pulling in air into your filter box without the snorkel. Here's the link:
https://www.scionlife.com/forums/viewtopic.php?t=123115
Yes, it will sound "throatier", and it makes your car sound "hip and cool". But, please keep in mind that it's going to pull VERY hot air from directly behind the radiator, and it will get worse when the radiator fan kicks on (especially now that we're in our summer months!) As a compromise, I removed the snorkel and replaced it with a 3" accordian style intake hose w/ clamp that runs behind the d/s headlight, and into the d/s front fenderwell. There's still a little raspy intake sound, but the intake temps are now consistently about 10-15 degrees above ambient.
- Al
Old 06-08-2006 | 04:12 PM
dude ill get better gas millage hows that bad?
Old 06-08-2006 | 04:23 PM
ASC's Avatar
ASC
George,
There's a compromise between better gas mileage and loss of power. Hot air = loss of power due to decreased mass of air. I've read somewhere that for every 10 degree increase, about 1% of your horsepower decreases. By pulling in air 30+degrees above ambient, your horsepower could decrease by 3-4 HP, negating any other mods you may have done or are planning to do. I can almost guarantee you that you'll feel the lagging response once you start pulling in the hot air.
FWIW, the 3" ducting is only $19.99 at AutoZone.
Now if your intent IS to increase your gas mileage, you may want to keep the snorkel on. The restrictive inlet will reduce the mass of air, keep it a bit cooler and still get you a better MPG reading.
I'm currently getting 34-36 MPG with "tempered" driving, and occasionally getting on the throttle.
Again, just offering some humble suggestions and observations.
- Al
Old 06-08-2006 | 04:33 PM
good point i think ill make a run over to auto zone ill let you know how it gose after i get it in
Old 06-08-2006 | 04:38 PM
ASC's Avatar
ASC
Short of getting a full blown CAI, I think you'll be happy. And maybe over $100 richer
Old 06-08-2006 | 06:02 PM
wow your idea worked well its not louder or faster or w/e but the responce is way better from off the line in normal driving i can rev the car less when coming from a stop and it seems to not mind it usally i would go up to alomost 2K before i would fully release the clutch now im at around 1.5K anyways its a nice mod and a good idea i reccomend it for anyone with a manual
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
steeze69
05-24-2021 02:57 AM
Sgtfluffy16
09-30-2015 01:42 PM
jbernard
09-03-2015 12:03 AM
Quick Reply: snorkel removal
