Straight Pipe!!
Straight Pipe!!
Anyone ever try this? I'm thinking it would be an easy DIY mod and it would gain some hp. also, would anyone know if it would pass emission?
If this ain't a good idea, what kind of aftermarket exhaust would be recommended?
_______
_______
If you cut off your catalytic converter you will not pass emissions. Also, if you do decide to take off your catalytic converter you will need an O2 Simulator to keep from throwing CELs.
______
______
just a little louder. love the deep noise and no torqe lost. actually gained which is causing a lot of cluth slip and not beacuse my clutch is old.
ma thread: https://www.scionlife.com/forums/vie...595&highlight=
--tom
for the test pipe where the cat was i just bolted it on. and for the piping i had to cut off the stock exhaust pipe (the flang side, inlet not outlet). so i welded that part to a 2 1/4" that i had a exhaust shop bend for me. i bought a stainless steel tip and tacked that on to the pipe. so it's the same as the bolt on axel back, but instead of an exhaust. it's a pipe with a tip. i wanted a jdm look so i had it at a up ward-right angle and sticking out about 3 inches from the bumper.
---tom
---tom
CrowJenkins
10-09-2015 10:47 PM
BlingSlade
09-05-2015 08:52 AM
