Unorthodox Racing Underdrive Pulley Installed
Old 08-14-2005, 09:21 PM
Grimstar's Avatar
what is WOT mean? sorry noob at this stuff.
Grimstar is offline
Old 08-14-2005, 09:27 PM
Munch's Avatar
WIDE OPEN THROTTLE
which means your gas pedal foot to the floor.
Munch is offline
Old 08-15-2005, 02:50 AM
jct
jct's Avatar
another noob question more like i forgot what it means
whats the benifits (pro's and con's) of an underdrive pully anyways
jct is offline
Old 08-15-2005, 09:29 PM
skinnerbox's Avatar
The pro's are increased horsepower and torque along with improved throttle response. Possible con's are reduced A/C performance and electrical output. However, in my case there isn't a noticeable difference in the A/C and it gets pretty hot down here in New Orleans. As for the electrical system, the UR website doesn't recommend using its underdrive pulleys on vehicles with stereo systems over 600 watts. Since I'm using the stock stereo, I should be fine.
skinnerbox is offline
Old 08-16-2005, 12:13 AM
Grimstar's Avatar
what if you have a hyper voltage kit and ground wiring an upgraded battery and spark plugs, along with spark plug wires, would that allow you to still the same performance and still allow a high powered stero. Im looking to be pushing over 2500 watts.
Grimstar is offline
Old 08-16-2005, 12:26 AM
skinnerbox's Avatar
The UR website recommends that people with stereo systems over 600 watts use a pulley that is not underdriven (like the Perrin pulley) or have them make a custom alternator pulley for you that will increase the voltage.
Old 08-17-2005, 08:49 AM
Grimstar's Avatar
so using the perrin pulley will allow me to build and use a high powered audio system.
Grimstar is offline
Old 08-17-2005, 11:27 AM
Munch's Avatar
It's not underdriven, so whatever the stock electrical system can take, with the Perrin pulley there will be no difference.
Munch is offline
Old 08-17-2005, 11:02 PM
ScionERA
deviousXA's Avatar
i would get a higher output alternator or have the oem one rewound for more power.......the whole thing is that your oem alt. wouldnt be putting out enough power from being underdriven to charge the battery as it should and for 2500+ RMS Watts safely i would 1. upgrade the alt. 2.possibly add a optima battery 3. atleast 3 farads of capacitors
deviousXA is offline
Old 08-17-2005, 11:19 PM
Scion_MILF's Avatar
love my perrin pulley
Scion_MILF is offline
Old 08-18-2005, 05:01 AM
gnar-de-gwar's Avatar
Is this pertaining to those who want and ahve alternate sound systems?
gnar-de-gwar is offline
Old 08-18-2005, 05:22 PM
Grimstar's Avatar
who makes, or where could i go to get an upgraded alt.? I live in S. Cali, L.A. County next to San Bernardino County.
Grimstar is offline
Old 08-18-2005, 05:36 PM
ScionERA
deviousXA's Avatar
define alternate? if its something small you should be fine without most of that but i would recomend to anyone running an amp to have capacitors .5F for up to500rms 1F for up to 1000rms and so on......the caps will keep your power draw from spiking on your cars power supply but like i said if its not a huge system should be ok (check what the fuses on the amp say and add up to that will tell you how much of a draw they take
Old 08-18-2005, 06:09 PM
sIcKsCiOnS
Fujiz_xb's Avatar
dang i was about to post a new thread about the pulley.. good thing i did a search first
here is my scenario
i want to add parts to the xb. this pulley beign one of them.
i want to upgrade to iridium spark plugs.
and in the future get a new sound system. i already have the 1or 2 farad capacitor and might get the yellow top battery.
exclusion from the battery, what else do i need to upgrade?
Fujiz_xb is offline
Old 08-19-2005, 12:25 AM
so basically, since I don't need to worry about it since I wont be doing any audio/visual stuff then...right?
Old 08-19-2005, 01:07 AM
Grimstar's Avatar
a little off topic but what about the perrin light weight flywheel?
Grimstar is offline
Old 08-19-2005, 05:04 PM
ScionERA
deviousXA's Avatar
Grimstar: as far as i know the perrin is ONLY lighter not a underdriven pulley
gnar: probably not but to be on the safe side get atleast a 1farad cap for every 1000rms watts you push
Fujiz: first off how much rms watts do you plan on pushing and how much current are the amp/amps gonna pull from the car ?
Old 08-19-2005, 05:16 PM
sIcKsCiOnS
Fujiz_xb's Avatar
prob gonna do 1000w amp 1000w tootal on subs. in addition to a 3-400 amp for the components. nothing big. my system was stolen so i dont have anything right now.
Fujiz_xb is offline
Old 08-19-2005, 09:19 PM
ScionERA
deviousXA's Avatar
stick a 1farad to your subs for sure but you might not have to stick one for your components unless you really are gonna crank em.....for subs when they hit hard and long the draw spikes high hence the caps but components are a little different......you could play it safe and run a .5farad to the component amp
Old 08-20-2005, 02:00 AM
TweeterXb's Avatar
just buy a nice amp like a jl slash series. They have regualted power supplies and don't need caps. I had 2 jl 1000/1 and 1 jl450/4 on the stock alt, just used a red top up front and a yellow top in the back. Was fine while the car was at about 1500+ rpm but would stall the car under that. I have removed that system since then and gone more towards the speed side of things now. I like to change stuff up often. Keeps it exciting, lol.
TweeterXb is offline
Quick Reply: Unorthodox Racing Underdrive Pulley Installed
