Where's the Oil Pressure Sender Located on the xB engine?
Old 10-17-2006 | 11:31 AM
BPG's Avatar
BPG
Default Where's the Oil Pressure Sender Located on the xB engine?
I'm in the process of installing VDO Vision Gauges in my xB. I'll end up having a total of 7 gauges. 3 are located directly to the left of the instrument (Water Temp, Vacuum and EGT) and 4 will be installed on an Autometer Pillar Pod (Oil Pressure, Oil Temp, Analog Clock and Outside Temp) Where is the stock Oil pressure sender/switch located on the xB engine? If you have pictures, Please post!
Old 10-17-2006 | 02:18 PM
ProshopXB's Avatar
There is an oil sensor on the front of the engine.. it's is a couple of inches above the oil filter and a couple of inches below the plastic intake manifold.. Sorry no pics of it thou... Mine is used for my oil feed line for my turbo, you can't miss it... it has a plug with one wire. But it will require you to remove the plastic shroud under the car to get to it and I would recomend taking the bumper off for even easier acess to it.
Old 10-17-2006 | 02:21 PM
jallamas's Avatar
Its dead center under the intake manifold, it has 1/8 NPT threads and it has a green wire with a gray connector going to it.
John
Old 10-17-2006 | 02:26 PM
ProshopXB's Avatar
John
Damnnnnnn.... good call Atleast some one paid attention to the colors of it.. I sure didnt..
Old 10-17-2006 | 02:44 PM
jallamas's Avatar
Thx ProshopXB!
Old 10-23-2006 | 12:35 AM
islandromeo81's Avatar
here you go if you still need help
https://www.scionlife.com/forums/vie...393&highlight=
Old 10-23-2006 | 01:04 AM
jallamas's Avatar
^^^^^^Good job! Thats great info!
John
06ScionTc5sp1
9
10-16-2020 02:18 AM
Col168c
27
04-09-2020 11:48 PM
my06tc
06-25-2015 01:18 AM
xxmanrd92xx
11
02-04-2015 02:40 AM
eric_m
79
03-17-2013 01:21 AM
