Write-up on transmission fluid change?
I looked in the tech section and there was only a write up for a Lexus.....does anyone have a write up on changing the transmission fluid on the xA, xB?
Its pretty simple. There is a drain bolt at the lowest point of the trans on the drivers side. Remove that to drain. About halfway up the transmission there is the fill bolt. Remove that and fill the trans up until the level is at the bottom of that hole. I think I used 2qts when I did mine.
Youll need a pump if you try to fill it from below or you can do what I did and buy a piece of heater hose, run it into the transmission, and pour the gear oil in from the top.
BE SURE NOT TO OVERTIGHTEN THE BOLTS! The transmission is aluminum and it will strip out easily!
write-up for tC
https://www.scionlife.com/forums/viewtopic.php?t=120673
same concept... but i usually just use a funnel or pump and get it thru the fill plug.
Re: Write-up on transmission fluid change?
Originally Posted by BrianxB
Its pretty simple. There is a drain bolt at the lowest point of the trans on the drivers side. Remove that to drain. About halfway up the transmission there is the fill bolt. Remove that and fill the trans up until the level is at the bottom of that hole...
is it for a automatic or a manual
every body else replyed for manual trans...
but for an automatic transmission idk if it has a drain plug... if it does have one drain it from there and take all the bolts from the pan out and soon as the pan is free, clean it real good and get all the metal shavings out away from the magnet and replace the oil trans filter and bolt every thing back up
if it doesn't have a drain plug its a some what a pretty messy oil change
loosen one corner of the oil pan bolts and take out all the other bolts out break the pan loose and let all the oil drain soon as its done draining take the rest of the bolts from the corner out there will be some oil left in the pan and clean it out replace the oil trans filter and bolt every thing back up
and fill the tranny fluid back thru the oil dip stick hole to the correct amount of quarts (pints two pints to a quart) with new tranny fluid and to be on the safe side run it thru all the gears and old it there for a moment in each gear to get the fluid flowing R-N-D-2-L and do it a couple of times just to make sure...
mischadoll
03-09-2015 05:48 AM
mrsocks
01-20-2015 01:29 PM
