xB Spark plugs Gap..Who should I believe?
I've read quite a few posts on spark for the xB. I just got my NGK Iridiums and am wondering which gap I should use?
Manual says .032-.034, other folks are saying .044. Which one is it!? Any help would be great. not really worried about gas mileage.
I do however like to give the local Civic drivers a run for there money.
__________________
__________________
Last edited by MR_LUV; 04-29-2019 at 11:21 PM. Reason: Moved to Correct Forum by Administrator
the iridiums come pre gapped..I was told at the auto parts store not to gap them
I'm old school so..this was tough for me
only got to use them for about 5k miles before the box got tot wrecked though
Look at the part number on the plugs ,
If the number ends with an 11 , .44 is the gap ( Prius plugs)
If it doesn't end in 11 , then go with the .32 gap
2004 to 2007 scion xb iridium plug according to ngk are to be gapped at .32
http://www.ngksparkplugs.com/apps/ca...gineid=1475655
japan bb ecu (1 o2 sensor) gap = 0.44
us xb ecu (2 o2 sensors) = gap 0.32
Or maybe my info is reveresed, can't be positive as i haven't checked in a while.. Yer best bet is to go by the specs in the owners manual, or use the specs provided at ngk.com.
Your owners manual is correct.
Also, it is never a good idea to gap irridum plugs, because the electrode tip is so small and fragile, it is very easy to break, thats why they come pre gapped, unlike traditional plugs that have a stonger and larger electrode tip which can stand some pressure put on it.
If you know what you are doing and know what can break if you are not careful, you could gap irridums, but why bother because they come pre gapped
Plugs
The NGK are pre-gapped, although I checked mine to make sure they were to spec.
You will not see any HP gains, though if your old plugs were corroded then you may feel more snap once the engine is getting the proper spark.
My fuel economy remained unchanged as well, but my idle smoothed out.
Good luck and enjoy!
yeah they are supposed to come pre-gapped but all 4 of mine I just got were off, so I gapped them. Just don't touch the center electrode you're good to go.
I have never put a plug in a car w/o making sure it's gapped right first.
Re: Xb spark plugs....who should i beleive?
Originally Posted by BlackBox06
i do however like to give the local civic drivers a run for there money
hahahaha i know these things wont make me go faster, just make the car run better. I was thinking about putting a huge spoiler on the back too, thats adds about 15 horsepower right?!
Re: Plugs
BlingSlade
09-05-2015 08:52 AM
cartier001
01-28-2005 10:34 PM
