1NZ-FE TRD Turbo
1NZ-FE TRD Turbo
Why is the TRD turbo kit for the 1NZ-FE not offered to the states. the Vios was offered limited edition from toyota turbocharged by TRD from factory. 143 hp @6400 RPM and 196 nm @4400 rpms. source http://paultan.org/archives/2005/11/...ta-vios-turbo/
seems it would have made the xB even more of a hot item had this been offered to us.
ecu is merely a technicality. it would have been an awesome "option", especially since they arlready had a turbo kit for it and ecu. the only thing i can think of is maybe emissions, however, if one was to go for the jdm kit, greddy emanage woud take care of the ecu issue. but with the several aftermarket turbo kits available for the 1NZ-FE it wouldn't make much sense to go through the hassle of getting a hold of a JDM Yota kt, it just suprises me that Toyota would not capitalize on the opportunity considering they already have produced turbocharged vesions of the 1NZ-FE
Team No Limitz
tuning issues...they use a MAP sensor instead of a MAF sensor and they run 100+ octane compared to our 91+ octane...running more timing to get those numbers over there is way less of an issue than being able to duplicate the numbers here with our lower octane rating...sucks to be us
Originally Posted by MattyRattyPoo
Its because the bB has a different ecu than the xB. Even if you got a hold of the TRD turbo from Japan, it wouldnt work on our cars.
Originally Posted by NeoXa
If you got the ecu, it wouldn't do much for you. The wiring harness is different to start, and the tuning on the ecu is based upon a 100oct level.
Yeah that work too. But you can't really the ecu at all, seeing as the tune is based upon what they give you when they put the ecu flash. And based upon a smaller motor. So piggy back or stand alone is kinda a must.
Mmm weird...... i live in Costa Rica and the Yaris Turbo from TRD has been available since 2000.... i has 150hp at the engine....not bad but not really good and the turbo is set up at 5psi..... course the engine is turbo prepared so I guess it could probable hold 8psi easily.
yes your engine should be cast iron sleeved like the rest of the XA and Xb ist whatever it should hold the pressure if you cannot modify with boost controller standalone or emanage or maybe even the primitive way of rising rate fuel pressure regulator injectors fuel pump possibly boost guage and turn boost up on wastegate just make sure to tune on dyno and leave set I would set it to the max you can where it leans out then back it off a pound just in case boost pressure spike protect the engine. the connecting rods are the weak link from what I understand if you cannot find aftermarket there are ways of strengthening shotpeening should be cheap I would suspect it could hold 10psi as a 1.6 single overhead cam honda I have holds 14 pounds no problem with all stock internals 125,000 miles now going strong plan in frame at 150 or switch to zc motor. I would suspect 210whp out of ur engine safely if done right
Anyone trying to go the JDM route will end up spending a ton more money than just getting a kit that is available in the states. Wiring harness? Sure, you can get the jdm wiring harness but those are COSTLY, not to mention the labor of pulling out your harness and putting the JDM one in, assuming all the sensors, etc are the same. All that time and money, you could have gotten 2 Greddy kits.
Re: 1NZ-FE TRD Turbo
Yeah people going the JDM route...don't so much worry about the money that goes into it. It's more about your car is showing you and what you want to have. Not what is cheap and just get just because..
No reason the xB's MAP system can't handle it with the 91+ fuel...
It needs some ECM programming... My mini is still using stock programming....
The xB was designed for fuel economy... but you can have both... I get 27mpg city and 35 hwy in the mini... and its heavier than the scion...
It's only time before someone comes out with a reprogrammer or a piggy-back unit for the ECU. But the xB still won't be as quick... its not designed for speed...
The other problem is also that the Toyotas/Scions dont use a map sensor. All the newer cars use a Hotwire sensor.
So what would you rather have? A bolt-on turbo for a econo-box that is factory set for fuel economy.. or a factory built car that is designed around forced induction?
There are twincharged minis running around with 350 whp. The box don't have a chance.. It is what it is...
Good luck trying to beat a cooper S with a xB.. blown or not..
