JUN Cams and XBG
JUN Cams and XBG
Well since I've been pushing the envelope with my motor a company in Japan known for racing cams has stepped up to bring me even more power. Junichi the owner of JUN Mechanics is sponsoring me a set of their turbo ground cams. These are not regrinds, these are a solid machined set. So now Ferrea is stepping up and sending me a complete valve train system. So I'll be using their springs, lockers and retainers and valves. This new head will be machined at AEBS in Ca. This is all the info I can release right now. But rest assure it will blow away that sh@t from Gude. I'll be making this new set up 9:1 compression and continue with 107 Torco fuel for now. This should turn into a great combination and finally give all you true hard core power junkies a reliable head platform to use. The cams are expensive about 1,600.00
USD. But could prove to be just the thing we need to open this motor up. You can check out their profiles at jun machine, just google it. A great JDM company. I'll keep you posted with progress.
XBG
XBG
steeze69
05-24-2021 03:57 AM
