Scion xA/xB Forced Induction Q&A
#42
Team No Limitz
Originally Posted by Bomex-bB
can you give me more detail on the fuel return system?
what i need and how it works and stuff.
Now so far i have e-management, spark plug and fuel rail on my way
What you will need for a return line is about 15 feet of fuel line, a few earls AN fittings, an aeromotive 1:1 FPR and I would get a bigger fuel pump while your at it...might as well change it out to something bigger like a 190 LPH while you got the sending unit out of the tank. I would also invest in some larger injectors if I were you...doing all these fuel upgrades, you will want the injectors to be able to handle that extra fuel.
#43
OK so far i have 4 310cc injector
Parts on the way or waiting to be installed is spark plug, e-management, power enterprise 130lph fuel pump, and perrin fuel rail.
Do you think those will fix the problem? is 130 lph big enough?
#44
Team No Limitz
yea, 130lph is fine...I was running a 255lph and that was completely overkill for the setup. You should be alright with that, just look into maybe doing a return line for safety reasons.
#47
Even if its a top mount, I am still going to go with the supercharger. I dont have room for an intercooler anymore with that new front end...
On another note, I already my hands on the turbo kit for the new ride....HAHAHAHA
#48
couple of ?'s.....
ok maybe a dumb one but trying to learn so....do you have to use top grade fuel if you go with the s/c? wondering how different t/c and s/c are
is an s/c less maint then an t/c?
last ? - with an s/c do you need to worry about cooling as much as you do with a t/c setup?
the cooling i was most curious about actually.
if anyone knows a good s/c vs. t/c comparison please point me i will do some reading!
thanks
thanks
#49
I am trying to replace my fuel pump to Power Enterprise 130LPH fuel pump.
I have no clue where the fuel pump is and all.
Asking for all SL people to help me out on this.
Can someone provide me with step by step or some direction towards this ?
#51
145hp at the wheels from 92hp stock. Greddy E-Manage, RC 310cc injectors, Iridium plugs, and ACT Extreme pressure plate w/ full face disc.
We don't have any codes or problems with the kit on our xB. Greddy will come out with a turbo and super charger set up next year. You might just want to wait untill next year when it comes out (BomexbB). It doesn't seem like you're sure what you want to do with the setup.
Good luck to you...
-Steve
Good luck to you...
-Steve
#53
fuel pump is in.
nothing too hard...
but stupid perrin fuel rail wont fit.
the end of rail where the fuel line goes is touching the fuel line hole and it wont sit on correctly.
thx to that i broke my fuel injector plastic and had problem with fuel leak....
good thing i had extra sets of o-rings and spare parts.
nothing too hard...
#54
glad to see perrin did nothing about the rail....
see this... https://www.scionlife.com/forums/viewtopic.php?t=48289
#56
Team No Limitz
dont return it, you will need it...just do what both Dave and I did and cut off that casted end(drivers side) of the block that looks sort of like a hook and you will be fine.
#59
Team No Limitz
If your not the handy type that is used to being under the hood and would be able to troubleshoot a problem or issue fairly quickly, then I would go with the supercharger instead of turbo but thats entirely up to you. If done correctly, both units can be virtually almost maintanence free. If you would like to see what is involved in doing a complete and "Proper" turbo setup, look in my profile for the xB and look in my power hungry mods. You dont need everything that I have, but like I said, if you wanna do it right you gotta spend the bucks.
#60
fuel pump is in.
nothing too hard...
nothing too hard...
I had no problems when I installed my rail from Perrin other than having to cut that stupid fuel line guard. Also, anytime you change the rail you should change the injector orings anyways. Its just added security.
