***HELP, new steering wheel troubles ****
Old 02-08-2007, 10:48 PM
jmseals's Avatar
Default ***HELP, new steering wheel troubles ****
please i hope someone can help., i got my new momo wheel this afternoon, got the momo hub for the xB installed everything fine, BUT left the airbag wires hang'n i was not able to fit them up into the hub so i pop'd the clip and removed it...... heres the problem i got in my box and ran to the store just now 3 min. drive took 20 min.s!! my traction control went ape sh*t, my box is /was bucking like a pony on crack, any ideas?? have i F'ed something up big time???? thanks for any help guys
jmseals is offline
Old 02-08-2007, 10:52 PM
dugzilla's Avatar
you can't take everything out, did you leave the little black piece that the grey plug goes into? If you take that out you will get the vsc and trac off lights.
You should be fine if you just unplugged the airbag and horn plugs.
can you post pics of the hub with the plugs?
dugzilla is offline
Old 02-08-2007, 10:55 PM
jmseals's Avatar
i'm thinking i F'ed up, i took the cover off to get the momo hub on, exposing the 6 or so little yellow circles, i'm kicking my own azz after this!!!
jmseals is offline
Old 02-08-2007, 11:11 PM
dugzilla's Avatar
I took that part out, under that is another piece that plugs into another harness. When I unplugged that I got the dash lights. I did get the vsc trac off at first and I was freaking out! I reset the ecu and it went away. I also had a loose clamp on my intake, so that may have caused it. I haven't had any lights for a while, and the car always ran fine. Did you get a check engine light too? or just the vsc trac off?
dugzilla is offline
Old 02-08-2007, 11:16 PM
jmseals's Avatar
i got the trac off after about 4 miles, then the vsc lighs and the car started bucking all over the road, i pulled over and it stopped, after get'n back on the road. i got the samething. when i start the car the only light that stays on is the airbag light
jmseals is offline
Old 02-08-2007, 11:21 PM
dugzilla's Avatar
All I have is the airbag light, but my car runs fine, do you have an auto or stick?
dugzilla is offline
Old 02-08-2007, 11:25 PM
jmseals's Avatar
5 speed
jmseals is offline
Old 02-09-2007, 12:04 AM
dugzilla's Avatar
I don't know what to say? Hope someone else knows what is up.
dugzilla is offline
Old 02-09-2007, 12:09 AM
jmseals's Avatar
i'm lost to, lol, maybe if i took the spiral cable assy out it would help? does the VSC have a fuse or something i can pull?? i looked and can't find one, i can't drive with the wheels locking up thats for sure, thanks for the help dugzilla
jmseals is offline
Old 02-09-2007, 12:28 AM
dugzilla's Avatar
No prob, if you get a chance take some pics and I will see what is different than mine.
dugzilla is offline
Old 02-09-2007, 12:42 AM
jmseals's Avatar
i just went and took the spiral cable thing out and took both the plugs lose, re set the ECU and about ta take it for another ride, crosing my freaking fingers, the closest toy dealer is many miles away, lol
jmseals is offline
Old 02-09-2007, 12:51 AM
jmseals's Avatar
well same problem , this sucks!!the VSC light comes on and it feels like the wheels are locking up, ERRRRRRRRRRR. if anyone has any ideas i'm open
jmseals is offline
Old 02-09-2007, 01:43 AM
swartzautoman's Avatar
wow man CRAZY! id be freekin too!
anyway your mistery vehicle is called a TIGER TRUCK made in japan. that one is all spiffed up. it has a 3 cilender mill. its mostly used at golf courses for maintenance stuff like a big golf cart. the ones ive seen have bench seet in the back and a vinal cover.
swartzautoman is offline
Old 02-09-2007, 02:07 PM
jmseals's Avatar
any body?? i took out the fuse for my ABS and i can drive it now, only thing is my speedometer is not working, i took out fuse #26, is there an other way to unhook the VSC??? PLEASE HELP
jmseals is offline
Old 02-09-2007, 03:52 PM
JIMXB's Avatar
To shut off the air bag light, you will need Two tiny 2 ohm power resistors (about $3) and insert/plug and tape ea into the 2 airbag wires. This will ground the connections and your air bag light will go out.
JIMXB is offline
Old 02-09-2007, 04:13 PM
jmseals's Avatar
the bag lights not bug'n , i need the VSC turned off so it'll stop locking up the front wheels, there has to be away ta do this
jmseals is offline
Old 02-09-2007, 05:14 PM
JIMXB's Avatar
Don't know what the f... you did. LOL. But to be safe spend the $75 to get it check out by a local installer. My custom steering wheel install was plug and play. Good Luck
JIMXB is offline
Old 02-09-2007, 06:01 PM
jmseals's Avatar
i only wish i knew! i'm kind of scared ta install my dc axel back and my cold air intake now, ,lol, she else could happen?
jmseals is offline
Old 02-17-2007, 04:30 AM
Kahuna's Avatar
Weird...Just finished with my momo wheel intstall, And besides the airbag light is on, all is fine.
Kahuna is offline
Old 06-21-2007, 11:09 AM
IV ACE
bB384's Avatar
What hub are you using? Did you disassemble the black plastic circular piece that was behind the stock steering wheel? If you messed with it, you need to replace it, that plastic piece has a sensor for the traction control so it knows what angle your steering wheel is at.
bB384 is offline
Quick Reply: ***HELP, new steering wheel troubles ****
