***HELP, new steering wheel troubles ****
Old 06-22-2007, 01:52 AM
Reactor's Avatar
Originally Posted by bB384
What hub are you using? Did you disassemble the black plastic circular piece that was behind the stock steering wheel? If you messed with it, you need to replace it, that plastic piece has a sensor for the traction control so it knows what angle your steering wheel is at.
Isnt there a cutout in the aftermarket hub for the airbag clock spring connector? All the airbag wires (2 pairs) the horn ground (1 wire) and audio controls go through that.
Reactor is offline
Old 06-22-2007, 09:13 AM
IV ACE
bB384's Avatar
Momo part number 7734 is the correct hub for scion xb's. But you can also use part number 7715, it will work but most people who try to use this end up yanking out the black piece with the connectors, or disassembling it and using half of it. Either way P/N 7715 is wrong, and you ought to use P/N 7734.
bB384 is offline
Old 06-23-2007, 02:23 AM
Reactor's Avatar
I have 7734 and it does not fit without modification on my 2006.5 with audio controls on the steering wheel. I will rather file it or use Dremel than remove airbag clockspring or loose horn and stability control function. MOMO actually doesnt list 2006 xB as a fit for 7734.
Reactor is offline
Old 06-23-2007, 08:15 AM
IV ACE
bB384's Avatar
Actually , I had that same problem, and I have a '04. I just used a dremel to bore out the hole to fit the harness/plug for the horn/airbag wires. I agree, dot not to mess with that clockspring/airbag reel/ whatever it is.
bB384 is offline
Old 09-12-2007, 07:12 PM
Iculook34's Avatar
I hope this helps but in that little black box if you take it all apart is (2) little gray gears... They have magnets on them that keep in contact with your traction control sensor. If you remove them you throw th VSC and set off the Traction Control. So what I did was trim everything away except the plug and those gears hot glue the two gears in place so the magnets are always in contact and your set. Then just tuck the little black box back inside the steering wheel housing and your ready to roll. I flipped out as well and i just started plugin stuff back in and that's what i found. The yellow gears and that whole thing is trash. Hope that helps i will try to take a pic of mine.
Mike C.
Iculook34 is offline
CombatmedicR56
11-12-2020 01:53 AM
fur_pig
03-20-2020 04:28 PM
bootlgr
01-26-2016 01:22 AM
FurionAlpha
Scion tC 1G ICE & Interior
01-12-2015 08:25 PM
Beesh
01-09-2015 06:30 PM
Quick Reply: ***HELP, new steering wheel troubles ****
