View Poll Results: 10w7 or 12w6v2
10w7
36.36%
12w6
63.64%
Voters: 22. You may not vote on this poll
10w7 or 12w6v2
Old 10-26-2005 | 04:29 PM
Jimmy's Avatar
Default 10w7 or 12w6v2
im gonna get my hands on a 12w6v2 and a jl audio e6450 amp this weekend from a trade. as most of you know, i have a 10w7 in my hatch right now.
im debating which sub to use. a local car audio(phile) expert told me that a12w6 will be better. this is advice from a guy who owned (3) 12w7's in his tacoma.
10w7=500w rms
12w6=400w rms
im going to use the 500/1 to power.
what are you opinion(s)?
Old 10-26-2005 | 04:49 PM
Scion-ce's Avatar
Which ever one you don't use, I'll buy from you
Old 10-26-2005 | 05:19 PM
drainbamaged's Avatar
From my roomate who used to own a shop I heard the 10w7's have a tendency to blow out and don't have the lasting power of a 10w6v2 so that's what i'm buying. Two 10w6v2's for about 140.00. Just need to find a kick ___ amp to go with them. Post pics when you get them installed, late!
Old 10-26-2005 | 06:05 PM
SCI_TC_GUY's Avatar
Originally Posted by drainbamaged
From my roomate who used to own a shop I heard the 10w7's have a tendency to blow out and don't have the lasting power of a 10w6v2 so that's what i'm buying. Two 10w6v2's for about 140.00. Just need to find a kick butt amp to go with them. Post pics when you get them installed, late!
that's a killer deal......where at??
Old 10-26-2005 | 09:27 PM
trebor's Avatar
Those are both nice subs!! You prolly won't be able to tell the difference between them, one has more power handling and a longer throw(10w7) and the other has more cone surface area so it doesn't need as much throw for the same output. I would prefer the larger speaker since it won't have to work as hard, to me that means less distortion. But if space is an issue then go with the smaller sub. You won't go wrong with either.
Old 10-27-2005 | 01:32 AM
Jimmy's Avatar
thanks for everyone's input.
keep them coming.
right now its 60% for the w7 and 40% 12w6
Old 10-27-2005 | 02:21 AM
ScionEyes's Avatar
KAD
i am no help, cause i am now very confused, i need to learn all this crap! or i will be in the dark for sure..
Old 10-27-2005 | 03:59 PM
Jimmy's Avatar
well definitely let us know when you plan to get your system. and we'll do our best to inform and point you in the right direction.
Old 10-27-2005 | 04:01 PM
Jimmy's Avatar
btw, polls are vice versa (sp?) 60%=w6 and 40%=w7
guess trebors post changed peoples mind. and makes me lean more towards the w6
Old 10-27-2005 | 04:41 PM
jager_kc's Avatar
I'd go with the W7..its a true SQL sub...thats just based on the systems ive listened to. 32mm xmax...mm..
Old 10-27-2005 | 04:45 PM
trebor's Avatar
Just checked on that, the xmax for the 10w7 is listed as 23mm not 32mm.
Here's a review of the 12w6 that I found:
http://www.caraudiomag.com/testreports/0403cae_jlaudio/
And one for the 10w7:
http://www.caraudiomag.com/testrepor...jla/index.html
Old 10-27-2005 | 05:04 PM
SCI_TC_GUY's Avatar
given rational installation and identical wattage input, the 12w6v2 will create more pressure than the 10w7.... making it a little louder....
Displacement for the 10w7 is 141.3cu. in.
Displacement for the 12w6v2 is 146.952cu. in.
Old 10-27-2005 | 05:07 PM
trebor's Avatar
For those that dont want to read the review, here's the results:
10w7:
SPL in car measurement at 2.83 volts, at 1 meter Peak reading non-weighted
40 Hz.................100.5 dB
80 Hz.................100.8 dB
Max SPL...............130.6 dB
12w6v2:
SPL in-car measurement at 2.83 volts, 1 meter Peak reading non-weighted
40Hz: 100.0dB
80Hz: 100.3dB
Max SPL: 129.7dB
Nearly identical!! You definately won't be able to tell the difference!!
Old 10-27-2005 | 06:39 PM
INSIDEOUT's Avatar
13 w6v2 is what I have and it is bad... I want two more......... It sounds good....
Old 10-27-2005 | 08:24 PM
xbderby's Avatar
....which is why I would no doubt go for the 12w6... main reason....10lbs lighter...same enclosure size... and could get away with a little less power with the 12w6 ( the 12w6 is slightly more efficient.
Old 11-18-2005 | 04:17 PM
Jimmy's Avatar
got some new toys
Old 11-18-2005 | 04:42 PM
SCI_TC_GUY's Avatar
Nice!!! when you installing it?
Old 11-18-2005 | 04:56 PM
Jimmy's Avatar
not sure. probably after christmas. gotta save money to buy christmas gifts
Old 11-18-2005 | 05:22 PM
SCI_TC_GUY's Avatar
gotta hate that
Old 11-18-2005 | 05:41 PM
natodog's Avatar
Default Re: 10w7 or 12w6v2
GO with the 10" w7 if u run 500 watts to it is louder than 2 w6v2 in a ported box. if you get the w7 you should get the high uotput box to go with it, i have personally heard these two subs go head to head in the same car setup, (not in the same car) one next to the other and we could tell the w7 was hitting harder, louder, and it sounded good.needless to say i would choose the 10" W7 in the high output box with a JL 500/1 running to it
