200 amp (120 idle) alternator for the xB
Originally Posted by invisible21
Originally Posted by GLN305
I'll try and get Dom over here. Keep in mind this alt is built with High Output as it's primary function, not getting as much out as you can by sacrificing idle output. Most rebuilders don't do it right, they wanna max out the internal therefore losing idle output and sometimes even total output.
Hopefully we can get a group buy going and get some xB owners setup!
Don't be too concerned with the wattage output of the amps. What you need to do is look at the owner's manual and see how much their max current draw is. If you exceed 60 or so amps, upgrading the battery may work just fine. If you are going over 80-100 amps, it's probably time to upgrade the alternator also. Another good thing to do is get a voltmeter and check the voltage with the car off, it will be around 12,8 volts. Now, you want to start the car, check the voltage, it will be around 14 volts. Now crank up the stereo and check the voltage, if it is below the car-off voltage, you need upgrades. Mine would idle at 13.9 volts or so, but drop to 11.2 when the stereo was full tilt.
I got one only 180amp though. but i have some problems. after install my battery light came on. i checked voltage at idle was only 12.3v. rev it up to 3000k voltage goes to 13.6. GLN305 what voltage are you running at idle and at peak. Isnt voltage suppossed to be about 14+v. I put my OEM back noproblems. Im waiting for DOM toreply.
At idle my voltage is around 13.6 and at 1200 RPM it's above 14. Did you make sure and plug the wiring harness in well? That's kinda weird that you are having the problems. Also, did you upgrade the main power wire, if not you may have blown the fuse on the factory main wire.
http://myspace-532.vo.llnwd.net/0065...54925532_l.jpg
I do see on large wire going from the alt ot the battery, so that's perfect. Double check that plug on the alt and make sure it's plugged in well and that none of the molex pins pushed themselves out and aren't making contact. I hope you didn't get a bad alt, but if you did Dom will take care of you. I would call him, he's a little slow on e-mails, but he has always answered his phone.
