200 amp (120 idle) alternator for the xB
Old 05-08-2006 | 04:34 AM
  #41
GLN305's Avatar
I'm pretty sure that it will fit, but call Dom to make sure.
Old 05-13-2006 | 07:04 AM
  #42
njforcedlife77's Avatar
quick question so i installed the 180 alt tonight and upgraded the wires and iam still getting dimming in my lights when the heavy bass hits anyone got any tips?
iam running this 2 Apine SWX-1042D, 1 Alpine MRD-M1005, 1 Alpine MRV-F545,Jenson VM9510TS With Mini sd Slot DVD,Alpine Center Channel,1 Ps2, Grounding Wire, Battery Wire Upgrade Phoenix Gold, so any one can help thanks
Old 05-14-2006 | 11:39 PM
  #43
GLN305's Avatar
Which battery are you running? Also, have you upgraded all the ground wires? I have a 2 gauge going from the battery to the stock ground on the radiator support, as well as one from the top alternator bolt to another stock ground point. I also used a 2 gauge from the batt to the ground bolt on the transmission where the factory ground wire goes just under the battery. I think the weak point for the xB is grounds. I am running an Optima Red Top and with everything stock but the battery and it helped alot. One last question...what size wire did you use to go from the alternator to the battery. You are gonna need at least 2 gauge, but preferably 1/0. Did you use the smaller pulley that came with the alternator? It is an overdrive pulley and makes the alt spin faster at lower RPM's.
Old 05-15-2006 | 12:06 AM
  #44
iam running a yellow top i have upgrade all the ground points iam running 2 guage on all the points and on alt.yes iam use the small pulley on alt so i have no clue what to do next but add a 2 farad cap think the amp are drawing so much.but what every one been saying that changing the alt would help in my case it didnt any can help thnx?question what are you running in yours?speakers amps?and all that fun stuff?
Old 05-15-2006 | 09:10 PM
  #45
150dBxB's Avatar
i got a 175 amp DENSO from h-o-alternator.com
its been awesome so far and it bolts on to the stock housing
all they do is alternators and they said anything over 175amp puts too much strain on the engine?????
Old 05-16-2006 | 03:27 AM
  #46
GLN305's Avatar
I am running an Orion 1200D and an Orion 4004, both amps together draw quite a bit of current. I have absolutely no headlight dimming with my alt. You gotta keep in mind that you may be drawing more than your alt can put out even though it's an HO alt.
Old 05-16-2006 | 06:22 AM
  #47
yes i think that maybe the trouble but just need to find something to solve the trouble so if anyone has any ideas let me know
Old 05-16-2006 | 03:05 PM
  #48
GLN305's Avatar
What may help you significantly is to run a second battery in the rear next to the amps. The alt is more than capable of charging two batteries. Also, you way want to upgrade the power wire going from the battery to the amps. If you are running 2 gauge then I would focus on trying to get another battery back there.
Old 05-16-2006 | 03:11 PM
  #49
150dBxB's Avatar
im running 0 gauge to the alternator and 2 runs of 0 gauge to the rear, you may want to upgrade your wire
Old 05-16-2006 | 06:43 PM
  #50
i have 2 gauge running from alt to the rear not dont know if that would help
Old 05-16-2006 | 07:07 PM
  #51
150dBxB's Avatar
i have the 175 H-O-Alternator.com ALT and:
2 runs of 0 Gauge
0 gauge to alternator
2 batcap 800 batteries under the hoof
1 batcap 400 in the rear
1 6 farad cap for my PG MS 1000
rockford bd3000x1
i am at 14.4 volts in the REAR and never go below 13 under heavy bass
its all in the alternator
Old 05-16-2006 | 11:52 PM
  #52
GLN305's Avatar
I didn't think that 0 gauge would make that big of a differenc, but awesome to hear...I may be doing it soon now...hehe.
Old 07-29-2006 | 08:53 PM
  #53
ahurdl01's Avatar
is there still a way to get one of these high outpul alts??
Old 07-31-2006 | 04:53 AM
  #54
PIMPmyPride's Avatar
Where under the dash do you run the large guage wires at?
Old 08-04-2006 | 03:35 PM
  #55
GLN305's Avatar
Sure, just go to caraudioforum.com and type in Iraggi Alternators, his info is there. I am at a library right now so I don't have all that info on me.
NonStopTuning
Scion FR-S Drivetrain & Power
14
05-05-2017 07:52 PM
pjl52
08-13-2015 03:38 PM
bmxScion
07-23-2015 01:07 AM
rancur3p1c
07-12-2015 08:59 PM
SFXB
07-10-2015 12:00 AM
