Ac Autotechnic gauges for the XA
Old 09-19-2005 | 10:32 PM
beigemonito's Avatar
Default Ac Autotechnic gauges for the XA
Where can I get the AC autotechnic gauges for my xa? Are they worth it? Does anyone have em? s it a _____ to install etc.? Let me know!
Thanks peeps,
Daniel
Old 09-19-2005 | 11:49 PM
Romanova's Avatar
Don't know where you get them as AC gauges are not my thing... rather go with a quality gauge like Greddy, HK$, Blitz, Defi, or VDO. Are they worth it? Yes... if you get oil pressure, oil temp, and water temp. Forget the 02 gauge, forget the volt gauge, forget the vaccumm gauge. Go with the engine essentials. Easy to install? That depends... if you get all the necessary hardware... sandwhich adapter for the oil gauges and an adapter for the water temp(Blitz Cooling Performer), you'll have an easier time. As far as wiring, it just depends on how comfortable you are with your skills. Can you find a ground, illumination, 12v switched power, and a constant power...(radio is a good tap), then you're set. Just figure out where you want to mount them... A-pillar pod or custom?
GL!
Old 09-20-2005 | 12:27 AM
Default I should've been clearer
On the part review here there are some gauges that replace the speedometer and rpm, those are the ones i'm lookig for. I don't need all those other gauges just something to replace the stock.
-Daniel
SloTC1
08-16-2018 03:45 PM
vi3tb0i09
09-23-2015 09:32 PM
brett561tc
09-15-2015 07:33 AM
paisatronix
09-05-2015 05:13 AM
