Aftermarket battery terminal ?s
Old 06-08-2008 | 09:32 AM
HondAudio's Avatar
Default Aftermarket battery terminal ?s
What are y'all using for aftermarket battery terminals? I need a 4-AWG cable coming from the positive terminal, plus the stock wiring, and the negative terminal is stock wiring plus two ring terminals for ground wires. What's that red box that hangs off the back of the positive terminal? Can it be relocated?
Old 06-09-2008 | 01:52 AM
HondAudio's Avatar
...anybody? Bueller?
Old 06-09-2008 | 07:06 AM
jallamas's Avatar
It has fuses in it. Get a battery with top mount and side mount posts. I can't be relocated easily.
John
Old 06-09-2008 | 07:07 AM
jallamas's Avatar
Originally Posted by jallamas
It has fuses in it. Get a battery with top mount and side mount posts. It can't be relocated easily.
John
Old 06-09-2008 | 03:01 PM
Black_Sheep_xB's Avatar
Yeah.. at first I used a large copper terminal for the 4 ga, and used that 12mm nut on the back/top of the OEM terminal to bolt it down.. had no issues, but had to cut a slot out of the terminal cover for the wire to fit through
I just switched to a Optima with top and side posts, added posts to the side terminals.. and used an "audio system" terminal with 2 large (4ga) holes and a few smaller ones for my accessories
Old 06-10-2008 | 08:02 AM
HondAudio's Avatar
Anybody have detailed pics? kthx
Old 06-15-2008 | 06:15 AM
kewlbox's Avatar
Not totally detailed pic, but this is the best one that i have.
4ga power wire from the pos. terminal.
Old 06-17-2008 | 08:44 AM
HondAudio's Avatar
I kinda wanted to upgrade everything with Stinger terminals...
revalina
12
12-27-2022 05:21 AM
idriveanxa
03-08-2015 01:03 PM
ScionRo
01-02-2015 08:54 PM
Thunder_xB
34
06-22-2004 08:17 PM
rolex87
02-28-2004 07:53 PM
