Amp Question
Amp Question
i have boughten a mtx thunder 4160 amplifier at a garage sale and its in perfect shape i was wondering what the power out put is its a 4 channel amp so if any one knows the specs plz tell me i tryed googlin it with no real luck.
thanks!
thanks!
20 Watts RMS/CH x 4 into 4 Ohms @ .1% THD 20-20,000Hz
40 Watts RMS/CH x 4 into 2 Ohms @.3% THD 20-20,000Hz
80 Watts RMS Bridged x 2 into 4 Ohms @.3% THD 20-20,000Hz
200 Watts Dynamic Power (IHF-202) Bridged x 2 into 4 Ohms (14.4 VDC)
Note: RMS Power Ratings @ 12.5 VDC Input
Google is your friend
there should be a channel 1&2 and channel 3&4... wire it to channel 1+ and channel 2- straight to the sub's + and -.... there should be a line connecting those 2 terminals I mentioned and it should say "bridge" on it... it'll just be a drawn/printed on line on the amp casing. It may instruct you to use Channel 2+ and channel 1- instead so just do what it says on the amp... only use 2 of the 4 channels available...
He said it's a single voice coil sub, not dual. Otherwise, I totally agree with you. Never hook individual voice coils up to separate channels of an amp. You are just asking for trouble. If you blow only one coil, more than likely, you would be SOL. Most manufacturers will refuse warranty service on a woof with a single blown coil. The manufacturer will assume it was installed incorrectly and refuse to replace it under warranty.
Originally Posted by george_da_2nd
ok i juts bought a 500 watt mono block so no worries hopefully itll be enough for my kenwood 12 inch
