antenna wire
antenna wire
damn, I accidentally cut my antenna wire, I tried to wire it back togeteher but when I turn my stereo on it just blows the ACC fuse. :? any idea why.. I think I might just do it all over and just buy a new antenna wire set-up so how and where do the wires connect to..
thanks
thanks
Re: antenna wire
thanks
thanks
Do you have an aftermarket deck?
it's the wire that goes into your stereo deck so it must be the power antenna wire..I'll try and go through my wiring harness and see if I crossed wires...could it be that crossed speaker wires may have messed it up, coz 'm pretty sure I got my ground/acc/power supply right..guess i'll check 'em again..
BTW glad to be the first of something
thanks
thanks
thanks
thanks
I dont konw if you mentioned if it was a stock or aftermarket deck?
If it was an aftermarket, did you use a harness adapter? If you did, the wires coming out of the aftermarket deck should match up identical with the colors on the adapter harness.
If you didnt and you cut your wires. Use a mulitmeter to make sure you have the proper wires going in to the right connections.
I believe the grey wire from the factory harness is your accessory wire. That wire should be hooked up to the red wire of the aftermarket stereo harness.
i have solid grey and striped grey for speakers, my acc wire from my harness matches the stock one which is yellow....i metered it and it shows power but my aftermarket stereo won't go on 'til the power antenna gets connected, but then when I do it just blows the fuse...thinking 'bout it starts to irritae me a lil bit....hopefully i won't be up all night trying to figure this thing out..
http://www.streetdreams.com/wires/toyota/general.html
Use that chart to match up the colors if you are not using a adapter harness. Your stereo should not turn on when you connect the power antenna wire then blow a fuse!
crystaljukebox_com
02-05-2004 05:53 AM
