Any carputers out there?
I've been contemplating a carputer and was wondering if anyone had some pics of their finished product.
What I'd like to do is keep my Eclipse CD7000 in the stock dual-din location and put a 7" double din touchscreen in the 'oven' slot.
Tips?
Tips?
Liliput 619GL-70NP Touchscreen in the stock dual DIN location.
I'm running a custom mini-ITX setup entirely hidden inside the dash.
2.0GHz Proc
2G RAM
500GB HDD
Audigy 5.1 sound
M2ATX DC-DC power supply w/ programmable startup/shutdown control
Windows XP Pro
Severely customized Streetdeck FE
-Audio, Video, 3D Navigation, etc., etc..
OBDII Decoder
Custom virtual gauges via DashCommand
I've been building carPCs for years. If you have any questions, let me know. I'll help any way I can.
It depends on the hardware, OS, and the way the PC is designed. I have mine set to hibernate when the keys are turned off rather than totally shut down. This allows me to do all sorts of functions in between the key signal and hibernation, like have my system check to see if my home server is in range, and if it is, check to see if the server has any new info (songs, movies, etc.) that is not on the carPC, then download that new material prior to complete hibernation. This way, I don't have to babysit the carPC while new material is added to the drive, which I do quite frequently.
I am running a 1400cca battery, so I'm not too concerned about the current draw, but I have the PS monitor the battery voltage anyway and if the voltage drops to 11V, the PS sends a complete shutdown to the carPC. Also, if the carPC is in hibernation for 4 hours, the PS will then send a shutdown as well.
My boot time from complete power-down, including shelling to the custom front end you see on the screen in the pic above takes a little less than a minute. From hibernation, it is less than half that.
Your only downfall to a machine with a hot processor is going to be power. Most DC-DC power supplies aren't running any higher than 160w and don't have the additional 4-pin 5V that is necessary to run the higher end processors. If you want to go this route, you may end up having to use an inverter to run the PC rather than the programmable power supply.
I'll check around and see if M2 and a few others have built their updated DC-DC supplies yet. I know there was rumor of a 320w that would support the AMD Athlon x2s, but I don't know if it ever was released.
Edit:
Found it!
http://www.opussolutions.com/index.php?p=product&id=49
The dual core Atom is a super low power processor. It is like 25w or something ridiculous like that at full load. It is 1GB memory and a 150GB SSD. So super low power and quick enough for a carputer. My laptop might be a bit much though so I will just turn that in to a tuning machine
Also, keep in mind that there are quite a few more possibilities in the ITX and Mini-ITX range now than there were in the past. Mini-ITX makes it very easy to use a MUCH smaller form-factor setup. My current system is ENTIRELY inside the dash of the xB without removing anything or modifying the top of the dash in any way.
I am also about to start working on my next setup with a different mobo, proc, memory, and power supply. This means that the brains of my existing setup will be up for sale if anyone is interested.
What would be up for sale would be:
VIA EN15000G w/ processor
2GB memory
M2 ATX programmable power supply
vettereddie
20
07-08-2008 04:17 AM
midtowndesi
35
08-29-2006 08:52 AM
midtowndesi
45
04-07-2006 10:41 PM
