Auto up AND down windows
Hey guys, did a search, but did not find this.
I have a 2002 4Runner with auto up and down front passenger windows. I swear to you that the window switches in my 4Runner look exactly like the window switches in my xB.
Here's the question: If I put a 4Runner auto down and up switch in my xB, will I now have that capability? I figure it wouldn't be more than $30 to purchase a new switch from the parts department. Anyone try this? Anyone have any ideas if this could work?
I really like this feature in my 4Runner and I hate not having it in the xB
By the way, my 4Runner is TCM, just like my xB. They look cool sitting side by side together in my driveway!
-Protoculture
-Protoculture
I could be wrong, but I don't think the switch panel holds
the relay that does the auto up/auto down feature.
I got some universal relays for my Porsche, I think they were
about $50 each window. I can try and find the site were
I got them from if your interested. PM me if you can't find
the answers your lookin' for here and I'll do some searching for you.
Hmm, so the magic happens in the relay rather than the switch? The switch itself looks the same from the outside, but the auto up and down switch in the 4Runner has that little detent where if you want it to auto up, you have to pull it just a little futher until it clicks. My point being, I would need to get a switch and a special relay?
I had a Toyota Surf 4WD (4Runner in US) in Japan with those same window switches and I was thinking the exact same thing. They look exactly the same. I'm having my friend in Japan to stop by a junkyard and pick up some auto switches and send them back to me.
I love the auto switches, but was dumbfounded when I pulled up on the switch in the Scion and let go... the window stopped as soon as I let go. WTH? I'd call that... sem-auto.
you can also go with the DEI 530T if you have an aftermarket alarm, it'll be auto up, down and can be controlled by the alarm.
www.directed.com
www.directed.com
Originally Posted by windowtint
the 530t's work well - but you will need 4 of them to make all 4 windows roll up AND down. One module can make one window up/down, or two seperate windows up (or) down only.
each module does up/down for two windows...
Originally Posted by www.directed.com
Part number: 530T (2 windows - up & down)
Part number: 529T (2 windows - up only)
if your friend can get them i'd buy a set from you....
I was just thinking that the tC switch and other components would be an easy install. The switch does make a difference as well. It is actually a 5 position switch internally. It has a Neutral position, UP, AUTO UP, DOWN, AUTO DOWN. Those are the clicks, or stops that you feel. You will need both the switch, and the control peices. I have not taken it apart so I cant tell you how they have the control set up.
Okay...the switch itself has NOTHING to do with the capability of going auto up and down -- it is merely a toggle.
