AUX jack
Old 09-19-2006 | 12:27 AM
ziggy3211's Avatar
Default AUX jack
I need some help - I have hooked up my Satellite radio through the AUX jack but I have a lot of engine interference (especially at higher RPMS). What can I do to minimize the interference? Is it the cord?
Old 09-19-2006 | 04:27 AM
watcher1307's Avatar
Wrap the wire with tinfoil.
Old 09-19-2006 | 05:09 AM
H20's Avatar
H20
I have the same problem. I did some searching and I am goin to try installing a ground loop thing from radioshack. I also plan on grounding the engine bay as described in the tech pages.
If anyone has info on the ground loop install such as where did you put it, does it need to be hooked to a power source??? ect....
Old 09-19-2006 | 05:15 AM
A ground loop isolator is pretty good too. No, it doesn't need any power. It just plugs into you rca's. That's it. It's as simple as that. One end plugs into the hu, the other plugs into the .......whatever. Simple!
Aluminum or Tin foil works too. It's cheaper!
Old 09-19-2006 | 05:16 AM
While aluminum or tin foil won't eliminate ground loops, it will reduce interference significantly at the point that the foil is located. That's basically what shielding the wire is. You can also try using shielded wires.
Old 09-20-2006 | 12:25 AM
ziggy3211's Avatar
Thanks for the tips - I will try the tinfoil this weekend.
Old 09-20-2006 | 12:42 AM
mfenske's Avatar
I actually even tried to re-ground the deck with no sucess. I ended up replacing the radio with an Eclipse unit and now have no noise issues. I wish Toyota would fix that aux noise issue. Mark
Old 09-20-2006 | 01:34 AM
samhain's Avatar
What is that AUX port for?
Old 09-20-2006 | 01:35 AM
For an alternate input source.
prescottn
Scion tC 2G ICE & Interior
04-26-2016 02:14 AM
prescottn
10-08-2015 06:31 PM
Scionxa180
09-24-2015 04:40 AM
Spitfire23
Scion tC 1G ICE & Interior
09-08-2015 04:31 AM
RokGoblin
08-11-2015 06:24 PM
Quick Reply: AUX jack
