best buy wiring harness
I (obvioiusly) really dont know anything about anything, so i was wondering if anyone could tell me what the toyota 87- wiring harness they sell at best buy is used for? can you use it to run a signal from the stock hu to an amp?
Usually its a 15 Wire Harness Consisting of 4 sets of 2 Speaker Wires (+ & - ) A Positive, a memory, a dimmer, an illumination, a ground and a Antenna/Remote (Amp) Turn on. The Remote Turn on wire (Blue) is connected to the usually blue wire included with an Amp Wiring Kit.
Metra Part Number 70-1761
For the Toyota, it has two small plugs.
http://www.audiooutfitter.com/store/701761.html
-Tuning
Circuit City Roadshop Installer
-Tuning
it is used when you swap out your radio for an after market one.
this allows you to keep all the factory wires intact (in case you want to put it back to stock for lease turn it or resale)
this wire harness will get spliced with the new radio harness then everything just plugs right in no hassles....
you can buy a regular harness (70-1761) and reverse harness (71-1761) from Best Buy and wire a line out converter in parallel with it to hook your RCAs to so youdont have to cut factory wiring.
O5_TRD_tC
02-18-2015 09:01 PM
clickclickw00t
02-18-2015 08:57 PM
