Boston Acoustics or JL subs?
Old 02-11-2005, 06:47 PM
tekniq's Avatar
Default Boston Acoustics or JL subs?
I am trying to make a decision but haven't ever heard the Boston's. I'm looking at 2 G510 or G512's (10" or 12") OR two 12W7's, either setup powered by a JL 1000/1.
If it matters, my mid/highs are going to be infinity perfect crossovers in the front powered by a JL 450/4.
So anyone ever heard these bostons? I am sure they have superior SQ but do they still get loud? The low sealed enclosure specs are nice (.5 ft) for the 10 inchers..
tekniq is offline
Old 02-11-2005, 07:06 PM
Reign_Man's Avatar
wow you realy got the cash for 2 W7s?...can i have a few bucks
Reign_Man is offline
Old 02-11-2005, 07:11 PM
VtScionGuy's Avatar
W7 all the way, but if you want to save some money get two ID Max V3's and buy a better amp, meaning non class D, like a used Zapco 6.0
Note: I have yet to listen to the Boston subs but have owned pair of W7s and the ID Max.
VtScionGuy is offline
Old 02-11-2005, 07:34 PM
chipzxb's Avatar
W7's all the way..
chipzxb is offline
Old 02-11-2005, 07:36 PM
SCI_TC_GUY's Avatar
w7's.......You'll only need one though.......2 will make your box explode.....
SCI_TC_GUY is offline
Old 02-11-2005, 07:46 PM
LavaScioninSC's Avatar
OK someone here's an idiot!
JL's slash amps are NOT class D
there full range mono-blocks!!!
Geez... and to think you suggest a Zapco over JL's,
you really are clueless....... I won't even go further on this issue with you.
LavaScioninSC is offline
Old 02-11-2005, 08:01 PM
Male_Nurse's Avatar
W7 man...ALL THE DAMN WAY. With the JL 1000/1 powering your 2 W7's, youll get the cleanest and not to mention the hardest hitting bass. Goodluck on your ears though, with that kind of bass hitting in your car your eardrum will explode. IMO, i'd just got for one 12" W7 in your car; 2 is over the top and basically used for competition purposes. If you're just a daily driver and not into that competing stuff, i'd rather go w/ 1 dub7.
Male_Nurse is offline
Old 02-11-2005, 08:05 PM
WildeScion's Avatar
I've had 2 12" 2 ohm Boston Pros before, and I don't think you'd be disappointed with the new & improved G series line. I beat the daylight out of my Pro Series, and they took every bit of it. If the box is built right, for the money, you'd have all the performance of the JL's at a cheaper price!
WildeScion is offline
Old 02-11-2005, 08:06 PM
tekniq's Avatar
Hmm.. 2 12W7's is overkill? I don't want to cause permanent ear damage, but I want to show off occasionally when little civics roll up at the stoplight beating on their Rockfords.. lol.
Is a 1000/1 too much for a single W7 or just right?
I like loud music don't get me wrong, but I don't like it being utterly unbalanced... Thoughts?
tekniq is offline
Old 02-11-2005, 08:08 PM
tekniq's Avatar
Hmmm these boston G512's are 4ohm it seems, would they perform similiarly with that 1000/1 amp?
http://www.bostonacoustics.com/ca_pr...&CategoryID=17
tekniq is offline
Old 02-11-2005, 08:12 PM
WildeScion's Avatar
I used my 2 2ohm subs on an MTX THunder 2300 amp, which wsa totally stable, but designed for the abuse. I assume the JL amp can handle it, but I'm not familiar enough with it to know for sure. Can the amp handle a mono load? If so, 2 Bostons bridged properly from 4 ohms to 1 ohm will work perfectly.
Old 02-11-2005, 08:15 PM
tekniq's Avatar
http://www.jlaudio.com/amps/10001.html says 1.5-4ohm at the rated power, I guess I need to learn some more about bridging because you lost me ;)
tekniq is offline
Old 02-11-2005, 08:23 PM
WildeScion's Avatar
I'm no pro, just going by what I remember.
If I remember correctly, 2 4ohm subs bridged together can create a 1 ohm load.But I may be thinking incorrectly....I haven't had my subs for 4 years and don't spend nearly as much time keeping up in the car audio world as I used to. I'd talk to a reputable local shop on how bridging 4 ohms subs works, just to be sure.
Just thought I'd give my opinion on your sub question.....sorry if I created some confusion.....
Old 02-11-2005, 08:32 PM
Lonely_Raven's Avatar
Ok, a little science to the speculation.
One JL sub should be fine if its in a good box. For each speaker you add (assuming
the same power) you only gain 3db. Hardly noticeable when you are already hitting
nearly 100db.
Two 4 Ohm subs in parallel will give you 2 Ohms. They share the load.
But if they are dual voice coil, you can go parallel/parallel for a 1Ohm load,
or series parallel for a 4 Ohm load.
But again, I think one sub is plenty WITH a good box and a good amp pushing it.
I think one speaker would be idea if it's a dual coil (which I think the JL are).
So if it's a dual coil sub, and each coil is 4 Ohms, they share the load and the amp
sees 2 Ohms (In parralel wiring). 2 Ohms is ideal for a good amp that can handle
low impedance.
Lonely_Raven is offline
Old 02-11-2005, 08:50 PM
WildeScion's Avatar
Lonely Raven, thanks for clarifying what I was trying to get to.....guess I need to spend more time brushing up on my stereo knowledge.
Old 02-11-2005, 09:32 PM
sleepytc's Avatar
JL ALL THE WAY. I HAVE 1 W7 12" AND IT'S BOUT TO BLOW OUT MY BACK WINDSHEILD. I JUST INSTALLED IT THIS PAST WEEKEND. HERES A PIC THE SETUP IS TEMP.
sleepytc is offline
Old 02-11-2005, 10:30 PM
VtScionGuy's Avatar
Were you talking to me?
Seriously?
Back the F off, If I was wrong fine, but don't call me an idiot. What is your experience with this amp? I've owned it and used them on W7's which the original thread starter was asking about. I simply mentioned a BETTER amp IMHO.
BTW: http://www.jlaudio.com/amps/curcuit.html
Have you used the Zapco C2K, JL 1000/1, or Boston subs? If not get off the thread.
I apologize tekiniq for doing this on your thread, just some people think they know it all irk me.
Old 02-11-2005, 10:37 PM
tcDreamz's Avatar
i will only buy JL but thats my personal preference.
u plan to get 2 w7 and a 1000/1 if im not mistaken i thought a 1000/1 is what it takes to power just one w7
tcDreamz is offline
Old 02-11-2005, 10:47 PM
VtScionGuy's Avatar
Optimum power for a 12W7 is 750 watts but you should be fine running two of them on a 1000/1.
The reason why I rec'd the Zapco 6.0 is that it does around 1200 watts @ 2 ohms mono. Now wire up 2 W7s and you'll get 1.5 ohm and that boosts the power output of the Zapco to aover 1600 watts realistically. And *poof* you get the optimum power.
Also I called up Zapco before I did this and they say the amp should run fine, and it never got hot in ym trunk.
tekniq's Avatar
Well, after seeing how large it really is in the trunk I think that I can only do 1 W7 and be comfortable in the hatch.
You're probably right but the JL website is down so I can't check to be certain. It seems that 1 sub is sufficient from everything I have read so far in this thread.
tekniq is offline
Quick Reply: Boston Acoustics or JL subs?
