Carputer / CarPC pics *Broadband Friendliest* tC
So about a year ago, close to when I first got my tC, I installed my carputer. It was pretty straight forward except for how to mount things so that they dont wear over time. Im finally posting pictures because I found a growing interest from the ScionLife crowd...
Things you might care about:
- Powerful (enough) computer... Pentium 4 + DVD / CDRW front mount drive.
- DeLorme Navigation
- Lilliput 7inch touchscreen
- USB powered **** for highering and lowering the volume, also for changing songs, and left mouse click (for when I dont feel like using the touchscreen)
- All is connected to an amplifier in order to utilize my car's original speakers
- Total cost ~ 800
- Total cost ~ 800
http://www.pvs-international.com/pics/020.jpg
that looks like the radio cover door isnt there with the liliput touchscreen.
i like the idea but i want the storage space in the glove compartment.
total cost of the install and devices?
theyre working now... they werent working at first because of size... so I fixed that
I installed this system myself, so those of you who were interested in doing this, feel free to ask any questions
and how do you like the liliput screen? ive been looking into it, but im skeptical on it's usage.. right now i have a flip up poweracoustik monitor, 7" and the svideo output w/a composite convertor makes the output from the laptop seem somewhat blurry... though ur pic looks good.
on the touchscreen, can you drag the pointer? or is it click/double click only... how about right click?
currently i use a wireless optical mouse
nice install btw!
nice install btw!
Very nice setup..Have a few questions:
How are you powering the laptop? Inverter? Shut off/on module connected to the iginition? How are you powering the liliput?
Thanks!
Thanks!
well, the 800 dollars breaks down like this: (keep in mind I got a lot of these things for a good deal)
Lilliput Screen ~220 (from Mp3car.com)
Volume Ctrl **** ~50 (from a MAC store)
Laptop w/ no screen ~300 (eBay)
Navigation Software + Antenna ~120 (microcenter)
Amp ~100 (got at a friends local shop- installed)
Power Inverter ~60 (circuit city, I didnt skip on this one, yes you can get them cheaper)
To answer some questions:
The **** is hooked up using regular USB... I ran the wirearound the center console (which comes apart so easily w/out unscrewing in the tC)... I mounted it using crazy glue
The lilliput screen is great, I also had a regular flip up Sony screen before the lilliput which was fuzzy... the reason is simply because it wasnt designed for high resolution computers. The screen has 3 wires coming out of it:
1) A regular VGA screen plug that goes into the laptop
2) A USB plug for the touchscreen (which is added to your computer as if it was a mouse, it drags & drops, and skips around- so its like a regular mouse, but has the ability to jump the cursor to where you touch)
3) A 12v plug for in-car use... I basically spliced the cig. lighter in the front and hid the second cig lighter I installed under the center console... took five minutes!!!
Was the Lilliput very hard to get to fit in the radio compartment. I am planning on doing a carputer setup this winter when I am trapped inside on a snowy weekend. Did you have to modify the screen or housing at all in order to get a secure fit while allowing the tC radio door to still close? Thanks for the help and I like the setup.
Great job, and i like the keyboard idea, i need to do something similar with my xB like that and an overhead light.
I like the volume know too, but man, can you really stand to use WMP10 all the time? Have you ever tried any other front-ends? I use FrodoPlayer and it's so much better then trying to hit buttons on WMP10! Check into the software on mp3car's forums if you haven't.
I'm enjoying my liliput as well, i need to mold it in tho
Very nice! Looks like I might be getting me a carputer sooner than I'd thought! I'm curious about the specs on the PC though - I'm a gamer, so tend to max-out specs that I don't really need to for a car. How much RAM, what speed CPU, and what kind of Sound Card do you have on that thing?
nice install btw!
nice install btw!
To fit the screen, I had to use the square bracket that surrounded the original head unit... I just drilled a tiny hole and sent a screw thru that heald the screen from the bottom (the screen already had a pre-drilled hole) then I pushed the screen upwards into the bracket for a snug fit... (and I padded it to avoid damage from a car's regular shaking and vibrations)
The tC radio door had to be chopped up... and I only use it to hide my screen when I park overnight
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
