Cup holder illumination Tip...
#41
Re: sweet!
Originally Posted by FASTER345
Hey do you guys know if ithe center console will lift off as easily on an automatic tranny car? (It's my wife's). I'd like to install these on her car...on HELL of a cheap christmas gift! ;) Cheers.
#42
for those who are adding switches for their cup holder illumination/oven bulbs, where are you mounting the switch? I was thinking of wiring the oven and cupholders to the same power source (coming off the line which gets power only when the dash lights are on) but then putting an additional switch between the power source and the lights so that the oven/cupholders dont HAVE to be illuminated if i dont want them on. I understand that's then sort of a two-stage switch (first dash lights need power, then need manual switch in the ON position) , but I wouldnt want them on if the dash lights werent on anyway ;)
so yeah, back to my initial question (disregarding my ramblings).... where are people putting the switch?
#43
#45
Originally Posted by funkenstein
this is a stupid question but what do you do with the blue plug once you have everyting wired up..do you just leave it unplugged?
#47
im not sure about all the voltage and stuff. i mounted my switch on the side of the console so it would be easier to wire and stuff. i went out and purchased the "LEDs Anywhere" for $8 and I'll be installing them tommorrow. I am probably going to run one under each cupholder, and then one in the cubby behind the E-brake.
I'll tell ya how it goes tomm!
#49
#50
Team Sushi
Originally Posted by transformerXA
hey i have a 04 xa and i tried to do this and when i went to plug the LEDs in it didn't light up. has anyone done it on an 04?
#51
Guest
Posts: n/a
I did my wifes XB automatic, used a $8.99 E-Bay set of multi color LED's that have options of staying on your choice of any 1 color, color changing (with speed control, changes colors slow, fast or anywhere inbetween) or pulse (___, changes colors at every beat of the music). Mounted them at the rear of the cupholders pointing forwardabout 1" off the bottom (so the dripping cup sweat doesnt short them out when it pools at the bottom of the cupholder) and mounted the supplied controller under the e-brake handle (low profile, doesnt interfere). The LED set I got had 4 LED's on 1 controller, I used 3.... 1 in each front cupholder and replaced the auto tranny shift position light with one also, now that illuminated strip next to the auto shifter changes with or stays the same color as the cupholders. I ran it off the auto tranny light wires with no problems because LED's draw next to nothing.
#52
i may just start doing all my leds i have like 50 i just gotta start wiring , i think i need to pay attention to other stuff for import motion tho friday's coming quick!!!
#53
does anyone know hoe the dealer's kit works or how it switches colors?
I've been trying to figure it out for some time...
yeah the multicolor leds i've looked at all do some crazy color spasm (all colors in 5 seconds) then cycle through the colors slowly (which is what i wanted) then spasm again...
My guess is the multicolor leds the dealers kit uses are full spectrum leds
like these:
https://www.ledtronics.com/datasheets/rgb.htm
which would allow you to select the color by powering one or more of the rgb colors.
but i havent figured out what kind of switch the dealers use.. or how they cycle through the colors (a dial switch perhaps?)...
if anyone knows, please post.
like these:
#56
Originally Posted by Epitrochoid
Originally Posted by Max
Dumb question: What's the "oven"
#58
Originally Posted by Matts xB
here are the lights that i just bought @ autozone. $9.99
they arent wired together and they are really small wires... What did u guys do to connect them??
Matt
Matt
I soldered all the leads together.
