Cup holder illumination Tip...
Old 07-26-2005, 01:50 AM
  #101
xBino's Avatar
Can anyone confim if the voltage coming out of the plug is 12v? I'm thinking of powering cold cathodes instead of LEDs through there.
xBino is offline
Old 07-26-2005, 08:29 AM
  #102
theomen21's Avatar
mods like these aren't going to void a warranty, are they?
theomen21 is offline
Old 07-26-2005, 11:34 AM
  #103
matt_a's Avatar
Only if you do something really wrong and it causes a problem that they can trace back to what you did. Other than that, you're fine.
matt_a is offline
Old 07-27-2005, 01:06 AM
  #104
xBino's Avatar
if you don't know anything about automotive electronics or basic wiring, i'd ask for some help with someone who does.
don't do a bad job the first time and spend 3x more time and effort to fix it
xBino is offline
Old 07-27-2005, 02:08 AM
  #105
MyLilXBox's Avatar
Originally Posted by matt_a
That is awesome! Thanks for the tip. I wasn't going to do the cup holder illumination for two reasons:
1. I'm 38 and my wife would laugh at me.
2. It's WAY too much money through the dealership.
But if I can do it for only $10, let her laugh! That'll be cool.
I showed my Husband this post and told him to go for it. He said a big Thanks. It took all of 30 minutes and 9.99 + tax. We went with the blue leds to match my blue box. It looks great tonight. This wife is happy.
MyLilXBox is offline
Old 07-27-2005, 04:09 AM
  #106
K3V
K3V's Avatar
I was just out with some friends and they both commented how cool they thought the cup holder lights were. It's definitely attention grabbing!
K3V is offline
Old 07-27-2005, 04:15 AM
  #107
strand23's Avatar
Great pics KV3!!
strand23 is offline
Old 07-27-2005, 01:33 PM
  #108
K3V
K3V's Avatar
Originally Posted by strand23
Great pics KV3!!
That's K3V to you
Here's a night time shot. My old digicam takes crappy night photos, but it looks sweet in person.
K3V is offline
Old 07-27-2005, 01:35 PM
  #109
ikhonlord's Avatar
Moved to ICE...I wonder why it took so long to be moved...
ikhonlord is offline
Old 07-27-2005, 02:00 PM
  #110
tynmagisa's Avatar
Default xB shifter removal
Unless I missed it, I still don't know how to remove the shifter covering off of my auto box. Can anyone explain how they did this?
Thanks!
tynmagisa is offline
Old 07-27-2005, 02:33 PM
  #111
matt_a's Avatar
Default Re: xB shifter removal
Thanks!
It's very easy.
Step 1. Remove the felt from the rear cupholder to expose screw head. Remove that screw (don't lose it).
Step 2. Remove the plastic piece in front of the E-brake (it just pops off).
Step 3. Grasp the front of the center console up around the cupholders. Firmly but gently, lift up. There are two plastic plug-type things under there that will pop loose. Be careful not to lose them, as they can fall free from the console and get lost real easy.
At this point, the console will lift right up over your shifter. There is nothing to undo around the base of the shifter on an auto trans.
matt_a is offline
Old 08-05-2005, 03:16 PM
  #112
2k5_BOP_xB's Avatar
Default square rocker switch
Originally Posted by Epitrochoid
Originally Posted by dmchale
so yeah, back to my initial question (disregarding my ramblings).... where are people putting the switch?
I used a round rocker switch from AutoZone and installed it in one of the blanks on the dash. I used a Dremel to make the hole in the blank then it just snaps back in.
Anyone know where to get the square rocker switch?
https://www.scionlife.com/gallery/da...switch1tn.jpeg
https://www.scionlife.com/gallery/da...switch2tn.jpeg
2k5_BOP_xB is offline
Old 08-05-2005, 03:35 PM
  #113
K3V
K3V's Avatar
Default Re: square rocker switch
Originally Posted by 2k5 BOP xB
It's a Gardner Bender switch (GSW-45 I believe was the part #) available at Lowes. I tried searching for the thread with details on it but the search is giving no results right now.
Edit: Found it: https://www.scionlife.com/forums/vie...hlight=gardner
You don't really need a switch, though - the LEDs will turn on and off with the headlights and dim with the interior lights doing the cup holder light mod this way.
K3V is offline
Old 09-02-2005, 02:20 AM
  #114
bblhed's Avatar
Just got my 12V LEDs toady, Pulled them apart and found that the resistors are 330 K Ohm, sorry I don't know that watage on these, I immagine that it is pritty low.
xBino; I highly recomend investing in a digital multi meter. Trust me if you plan on owning anything ever that uses electricity an $80 meter will save you thousands over your lifetime, and it will tell you the voltage of the wires you want to know about for your cold cathode. Hint, most auto electrical systems are 13.2 volt not 12! I will post voltage when I install my LEDs
bblhed is offline
Old 09-03-2005, 03:27 AM
  #115
bblhed's Avatar
Being true to my word I have checked and have the information you wanted.
With the car off I Read 12.15 Volts DC
Min voltage I could get to with the LED's still lighting 2.4 VDC
With the car on and running 13.6 VDC
Voltage Confirmed. I didn't check on Ampers, that should be goverened by the fuse. Remember you do not want to overload the wiring on your brand new car!
If you want to know the Amperage draw of whatever you are instaling just use Watts Law W=VA Where Watage=Voltage times Ampers
Convert that to Watage/Voltage = Ampers and you will have your Amperage draw. Math, works every time.
bblhed is offline
Old 09-12-2005, 08:58 PM
  #116
xBino's Avatar
You ROCK! Thanks man!
xBino is offline
Old 09-13-2005, 11:42 PM
  #117
bblhed's Avatar
For those who want Cold Cathodes, and fell into this thread, I'm sure you could find this info some place else, but When you hook them up you might want to connect them to the Cigarette lighter wires, That is where Toyota hooks the under dash dim overpriced Leds. I did the my cold cathodes folowing Toyota's instructions for wire hook up using a wiring harnes I made myself with some improvised mounting positions that IMO look cleaner than Toyotas.
bblhed is offline
Old 09-14-2005, 01:30 AM
  #118
Short_Bus's Avatar
I read this post earlier today and rushed (not really) to autozone and got my led's. They turned out so good, they are blue check my sig for pics
Short_Bus is offline
Old 09-15-2005, 01:13 AM
  #119
raltiero's Avatar
I told my wife about this and she said to go for it.
raltiero is offline
Old 09-17-2005, 11:19 PM
  #120
KAD
rebelMan's Avatar
will this work on my 06 xB?
rebelMan is offline
Quick Reply: Cup holder illumination Tip...
