Determining Cubic Feet
since i can't find what i want, i'm going to build my box for my subs. i need .65 cubic feet of airspace and want to know how i can figure out how much space i have or need. i'm putting a pair of 8's in an angle cut box in my xa and this is what i have to work with. i need the box to be no taller than 12", no longer than 36", and the bottom depth can not exceed 9". i have yet to determine the top depth since i pretty much started taking measurements last night in the dark.
i'm planning on using 5/8" mdf since from what i've read, it should be more than sufficient for my application. any help would be appreciated. thanks.
Length times width times height (measured in feet)= cubic feet. for a speaker enclosure you need to measure the inside of the box or be sure to subtract the MDF thickness from the calculation.
bird, what do you mean by divide the box into a cube and a triangle?
so i don't need the top depth in order to get my final number? what i was looking for was a formula since i thought i would need the top depth for sure. am i mistaken or what?
an angled enclosure is essentially a box with a (3D) triangle on top. so find the air space of the box, then the airspace of the (3D) triangle and then add them together to find the total air space...
and as someone else has already pointed out, the basic equation for a (3D) triangle is:
Originally Posted by emokid158
for the triangle portion it's half of the base times the height times the depth
found a link on another forum that answered my question. thanks for your help guys.
http://www.rockfordfosgate.com/rftech/boxcalculator.asp
ted, thanks for the heads up but according to the calculations i got on the rockford link i posted earlier, i'm right where i need to be including the dividing wall. i'm ok with numbers but i'm glad i was able to use that link. it saved me a lot of trouble. now all i have to do is build and carpet it.
i have so much work to do it's not even funny. between the amp rack, box, components, wiring, screens, back up camera, and sound deadening ,i won't be done for at least 2 weeks. but you can be sure once i'm done, pics are coming. lucky for me i have friends that are willing to lend a hand.
mischman
09-15-2015 04:38 PM
allscion
09-06-2004 07:36 AM
