Door card upholstery question.
I recently installed leather seats into my xb and i want to finish off the look by changing the cloth inserts on the doors to leather. Well i removed one of the door panels and found that the insert seems to be bonded in?? If anyone has any experience with these doors pleae help me.
Thank you.
Thank you.
The inserts are certainly glued into the panels. I had an upholstery shop install mine after I tried one (not particularly successfully ) They glued the inserts in after doing some trimming of the original cloth where it pokes thru the door panel. As best I can tell they left the rest of the old fabric in place (not sure I am totally happy with the result as it is far from perfect...but it is presentable). In any case they did what I wasn't equipped to do...can't get truely professional glues readily...I have no upholstery tucking or special cutting tools...(also they saved me from throwing my door panels thru the nearest wall while cussing at the leather).
Thank you. So it looks like i will be trying to cut these out and re-install them... i still have my templates so hopefully i will not have to start from scratch again. Ted the door card would have surived the wall impact... I got that frustrated lol.
I just did my door inserts tonight. The best method I found was to use a small razor knife and run around the groove where the factory material is tucked in to break loose everything. Of course then comes the fun part, pulling off the material. Depending on age of car and exposure to sun, you may get lucky and take the foam and cloth off in one try, but if not, get some 40 grit sandpaper or a dremel with a wire wheel and take the foam off. Of course now you need to either tape the area to be glue off or like I did, use a piece of posterboard in the groove to keep the glue from going where you don't want it. If you get glue on the panel, no worries, Goof Off will remove it and not damage the panel at all. Pic of one of my panels done is uploading, will post link when it's done.
that install looks REALLY nice! I'm in the same predicament as the original poster as I just installed leather for the seats myself and took one door panel off to check things out. I didn't see any way to remove the whole part that the cloth is on and put it back on.
GLN305: did you completely remove the part with the cloth on it or just the cloth itself? If you removed the whole part, how did you do that and then re-attach it? I'm a big believer in doing it myself, but not if I'm gonna totally screw it up.
My understanding is the leather inserts go over the fabric and you use a upholstery tucking tool to get the edges clean. dry fit first, trim if need, then use the glue (DAP spray adhisive). Getting my leather kit this week hopfully it'll go smooth.
