Eclipse AVN6600 - ground wire?
Old 07-20-2006 | 05:55 PM
syztematik's Avatar
Default Eclipse AVN6600 - ground wire?
I just installed my Eclipse AVN6600 and was wondering if anyone knew or knows a place where I can find out about grounding the e-brake wire for the AVN6600. Thanks.
Old 07-20-2006 | 06:17 PM
LeroyJMC's Avatar
I grounded mine along with the normal ground wire for the head unit at the kick panel on the driver's side. Doing it like that, then you don't have to remove the console around the brake/shifter.
Just find the wire that's marked for the parking brake and connect it to a chasis ground. It's on the connector with the reverse lights and speed sensing wire.
Old 07-20-2006 | 08:27 PM
mat18's Avatar
on the Eclipse AVN6600 could you ground it to a switch to watch a movie and drive.
Old 07-20-2006 | 09:01 PM
LeroyJMC's Avatar
There's no need for a switch, just a straight ground. However, if you wanted an inline switch, then that would work too.
Nerdcore314
05-02-2015 12:54 AM
randode
44
06-29-2004 05:19 PM
pmpnxb
11
01-27-2004 05:36 AM
bryanrx7
01-01-2004 10:53 PM
deathcabforme
10-16-2003 05:02 AM
Quick Reply: Eclipse AVN6600 - ground wire?
