Eclipse Nav install question
We're picking up our new tC next week, and as a surprise for my wife I want to get her an Eclipse AVN 2454 nav/dvd system. The prices on eBay aren't too bad, and I'm thinking of doing the install myself. However, I have never done any kind of electrical install on a car before. I'm an IT tech so building computers is nothing new, but car electrical systems scare me
So, how easy is it to remove the existing head unit, and what can I expect to find back there? Is installing the Eclipse going to be "plug and play" or will there be wiring and soldering involved? Any help would be appreciated.
Thanks
Thanks
It's going to be super easy on the electrical front. The standard Toyota/Scion wiring harness is the same as the Eclipse harness (because Eclipse makes most of the standard Toyota head units.) You won't even need a wiring harness adapter, just unplug th estock stereo and plug in the Eclipse.
You might need to drill the bracket or something to position the AVN 2454 so the door will close. You might also need to make some filler plates to hid=e gaps on the side.
I still want to sell mines
Interested?
Unit + remote $1,350 shipped. Money Order or Checks Only. Item will be sent when check clears.
https://www.scionlife.com/forums/vie...ab7f88e9e17873
You will have to drill the brackets to get it to fit just right. As for the gaps in the side Toyota makes the trim pieces to accomplish exactly that. Here's the part numbers:
86221-52060
86221-52050
They run $16 each and expect the parts guy/gal to give you the WTF look, they're in their parts system as something unusual. But, trust me just get them to order those part numbers and you'll get what you need.
Here's a pic of mine installed with the trim pieces (can't really see them), click on it for a larger version:
86221-52060
86221-52050
Cut?
Did you have to cut the round tubular thing in back on those side pieces?
If you take a look at my pic, those are the side pieces but I had to modify mines a bit in order for them to work. Plus only one hole align correctly with the side pieces which is strong enough to hold it in place.
86221-52060
86221-52050
86221-52060
86221-52050
Originally Posted by JSVH
What about the speed sensor and the GPS antenna? Where and how did you splice into the speed signal? Where did you put the GPS antenna?
To be specific, I ran the antenna cable from the antenna, down the dash through the drivers kick panel by the dead pedal and then across to the head unit.
I can't remember which wire is the speed sensor but I called my dealer's service dept and they were able to tell me so I spliced into that.
Also, if you want to be able to change destinations and such while driving (or watching a movie in stopped traffic) make sure the wire that goes to the parking brake is always grounded.
Don't cut corners, attach to the backup lights as well per the instructions so the unit knows when you're reversing. I cut this corner and until I corrected it the GPS got confused when I backed out of my driveway and thought I was on another street or not on one at all until I either turned or the GPS got a good satellite lock.
Re: Cut?
86221-52060
86221-52050
86221-52060
86221-52050
86221-52060
86221-52050
86221-52060
86221-52050
will these work for the gap with the Kenwood DDX7015?
Also, how do the trim pieces attach? do they snap on? glue? screws?
wiltonhall
01-28-2015 03:46 PM
TheRedBox
31
12-02-2003 04:53 PM
