factory alarm...
omg this is so ghetto.. i'm not sure if its the alarm or not but wen i hit the unlockbuton on mah alarm. it has a relay inside so im sure thats probably it. and when you unplug the harness that goes into the alarm unit. ur power door locks dont work! so i dont think we can unplug the stock alarm unit... any suggestions people? thanks!
Re: factory alarm...
Originally Posted by swtbabiboi4u
does anyone know where our factory alarm is located in the car.. i wnat to rip it out so i can slap on a new cliffard alarm im about to pick up... Thank You :D
Not a good idea to take it out they are wired in to other parts of the car. Most istaller will know how to disable your factory system with the Clifford system. You should not need to do anything at all though. When I installed my Clifford Matrix system I did'nt have any problems with the factory system arming along side the aftermarket system. With my wiring info I have here in front of me, I dont see any wire color that will disarm the factory system, which ussally means that it will not cause a problem.
steeze69
05-24-2021 02:57 AM
