flip down monitor help
Old 04-29-2006 | 12:55 AM
DaToaster's Avatar
Default flip down monitor help
how do i instal an overhead flip down monitor? plz help me...
Old 04-30-2006 | 02:30 AM
kzhorse's Avatar
Strictly Scionized
All I can say is you will have to add support above the head liner to hold anything more than a dome light.
I used a 12" wide strip of 1/2" plywood to span from side to side above the head liner.
When you pull the head liner down you will see plastic supports above the doors all I did was rest the plywood above that and it works perfect.
And I ran the power and video up the passenger side behind the "A" piller.
Hope this helps and what you were looking for.
Good luck,Scott
[/img]https://www.scionlife.com/gallery/personal/thumbs/15359_15.jpg[img][/img]
Old 04-30-2006 | 04:03 AM
H8me's Avatar
sry. as an installer if u have to ask that question u shoud seek professional instalation. puting an overhead on a roof corectly requires buildin a brace, cuting of the headliner, running, wires through the headliner, and most inportant no extra antennas on the roof (screws holes in to that nice water tight sheet metal)
Old 04-30-2006 | 05:12 AM
ProshopXB's Avatar
I agree with this, i do it for a living and overheads still scare me a bit. the thought of sending a screw thru the roof, is just a plain nightmare. Seek a professional or someone who has some more experience to do it for you.
Old 05-01-2006 | 04:20 PM
tbone587's Avatar
Yeah... We did an overhead yesterday at circuit city on a chevy tahoe and it was a hell of a lot of work. We mounted a piece of plywood under the headliner and we also had to grind down the trim ring around the overhead to make the screen sit flush with the hump on the headliner. Turned out great, but its not the funnest install..
Old 05-01-2006 | 04:41 PM
INSIDEOUT's Avatar
You do not need to put a dang peice of wood in the xb if you know what your doing! I have a 10.4" drop down, I used the existing bracket it came with, pulled the light down and mounted it where the light went! You just need to be very careful you do not screw thru the top.... Get a drill bit that is smaller than the screws tap it for the screws then proceed with the install..
It is very simple just time consuming, you also need to make sure it is centered!! Good Luck!
Old 05-01-2006 | 04:47 PM
ElChupacabra's Avatar
Yeah, 10.4" flip down in mine and I didnt need any additional supports. I did have to drill 2 extra holes into the existing cross beam. INSIDEOUT is exactly right. Just use a bit that wont reach to the roof. I never cut the headliner or added anything. If I wanted to I can take out the flipdown and rock the dome light again without ever knowing it was there...
...SEEK PROFESSIONAL HELP!!!
Old 05-01-2006 | 08:38 PM
kzhorse's Avatar
Strictly Scionized
Thats fine if you are putting the monitor for the back.
I was talking about up front between the visors,You need support up front.
Scott
Old 05-01-2006 | 08:49 PM
hXcdi3hard's Avatar
Flip downs are a B***H in this car had to do one at work man its a pain.....my advise take it somewhere to do it its only like 100-150 to do it...
Old 05-01-2006 | 08:50 PM
Well if you wanna put one in the front that is true. You'll need to brace...
Old 05-02-2006 | 02:47 AM
DaToaster's Avatar
i put one in the fron that was easy well i had it custom but yeah im putting this one under the light... all i need to do now is drill the metal for the tv to the support right now its just hanging fro the headliner its self
alexdrummerr30
09-08-2018 01:18 PM
neneago
10-27-2015 05:47 PM
torqueTc
10-08-2015 06:39 PM
That_Kid_Ju
09-30-2015 11:05 PM
StxArOne
Scion xA Aero & Exterior
08-29-2015 04:29 PM
