Gauge And Center Console Color LED Conversion
Originally Posted by TheBigGuyRy
Man that is so sweet. I would give anything to know how to do that.
https://www.scionlife.com/forums/viewtopic.php?t=37747
https://www.scionlife.com/forums/vie...=37747&start=0
It takes about 1.5 hours. Just take your time, get a 15 watt pointed tip soldering iron from Radio Shack.
Buy the LED's from here
http://www.lc-led.com/Products/department/5
Dig in.
ScionDad.....I was seriously considering this MOD but am very afraid of messing up....i am not very familar with soldering....i have used a high temp one for wood and other various engraving...but not a low temp one....In your honest opinion how hard was it and what is your skill level because mine is one the low end???
How would you rate difficulty on something like that?
Really I'd say it depends on experience level. If you've used a soldering iron before, I'd rate it a 3. Except for removing the LCD screens, that I'd rate a 6 or 7. ScionDad's right, taking it apart (especially the center console) is the worst part. If you have no experience, then I recommend getting a couple resistors (a few cents a piece) and a project board so you can practice your technique before tackling the gauges. But as long as your hand is steady, it shouldn't be that bad.
I wouldn't recommend using a wood burner for soldering, you run too high a risk of frying something. Get a cheap 15W soldering iron from RadioShack for like $12, it does the job just fine. Also if you decide to do the LCD in the center console, DO NOT PRY, people have cracked this thing pretty easily. Get a desoldering pump or desoldering braid and remove the solder from the pins on the LCD, it'll come out easily then. All in all, you'll need approximately 40 LED's and 1.5 hours to do the job. Good Luck.
Originally Posted by jmiller20874
Yeah I downloaded it a while ago. There is a schematic for the combination meter (aka gauges) and it looks like the gauges supply the power for the illumination of the console. Like you mentioned about a month ago, the voltage could be increased there. I see a problem with this though, the voltage would also be increased to the other LEDs that were left stock in the console (and actually are bright), that might cause the stock LED's to fry
Sorry man, I'm still working on it. I had a busy weekend and didn't get too much oppurtunity. When I'm done, I'll email my findings to you and ScionDad so I can get both your expert opinions on where to tackle this. Hopefully I'll be doing it tonight. Hopefully the resistor(s) we need to replace aren't those super tiny ones, that would suck.
14 for the gauges if you replace just the gauges and the odo LEDs. 14 will get you what you see below on mine. You can replace the other lights (turn signals, dummy lights, etc) if you want as well, but I left mine the way they were.
