Ground wire kits...
Ground wire kits...
Ok I've seen a few ground wire kits floating around ebay... question here is, how well do they work? I'm not all that farmilliar with em, and 5-8hp gain from re-grounding a few wires? sounds odd to me, but for the money If they really make the box run better it may be worth investing in... any comments on the JDMs?
http://www.importtuner.com/tech/0212it_ppsuzuki/
That's were it was. They said 3-4 on the aerio. I guess it depends on how crappy your ground wires are to begin with. I can't imagine them being THAT bad that you'd get more than a couple hp.
sIcKsCiOnS
DelMarVa
Scion Tuners
Originally Posted by mrlaypo
ok... is there any functional difference between a $30 set and a $100 set??
Doc
DelMarVa
Scion Tuners
DelMarVa
Scion Tuners
search button= the answers you are looking for. and for the HP thing it really does NOT gain HP ,it GIVES the ELECTRONICS in the engine a better source of current THEREFORE unleashes HP that is already there. and yes there is a difference in speaker wire and ground wire, and yes the 65$ ground kit should work just as good as the 100.00 ground kit.
yeah the grounding kit is more for us stereo guys because it helps to stop dimming from headlights and allows more current to flow when your drawing a lot of amperage from your amplifiers. but i really dont think it will make that much difference performance wise to your car, maybe as noticeable as having a full tank of gas to having a 1/4 tank of gas, or accelarating with someone else in your car vs. just by yourself
Nerdcore314
05-02-2015 12:54 AM
randode
44
06-29-2004 05:19 PM
sithscripter
03-31-2004 05:02 AM
